Orange Strip Removal Guide
Old Feb 19, 2004 | 09:33 PM
mgl's Avatar
mgl
allow sealant to dry.
put the headlight back on the car.
put the bumper back on and you are done!!
hope this helps.
big-al is a true expert at this mod, so i hope i sufficiently relayed the info. and instuctions.
alan: please add to this guide if i missed anything
i tried my best to remember everything you told me, but i'm sure i left things out.
warning: this mod is very time consuming and requires a lot of patience.
Old Feb 19, 2004 | 09:57 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
Great Job Michelle...
Old Feb 19, 2004 | 10:38 PM
mgl's Avatar
mgl
oh yeah forgot to post a pic of the final product:
Old Feb 19, 2004 | 10:39 PM
mgl's Avatar
mgl
and one more with the led lights on
Old Feb 19, 2004 | 10:59 PM
mgl's Avatar
mgl
heres a pic of the heat gun and sealant that we used.
Old Feb 19, 2004 | 11:01 PM
aaaaa's Avatar
aaaaa
wow you guys did lots of work....nice headlight man...
thanks for the steps but..it is too risky...i think i have think one more time to do this...=)
Old Feb 19, 2004 | 11:22 PM
Z-INCOGNITO
It's not as bad as it looks... but its definitely not easy either...
Old Feb 20, 2004 | 02:21 AM
DruDragzOn's Avatar
DruDragzOn
Great writeup! Great job as well. It came out perfect!
Old Feb 20, 2004 | 06:55 AM
yobri's Avatar
yobri
Excellent write-up and visuals, 'chelle. I really wanna do this with a group... preferably those with a little more experience with such alterations, namely with Audiomobile if possible. I'll stick around to see what other generated interest in the BA occurs to see if OSRM II will go down.
Old Feb 20, 2004 | 01:36 PM
MGV156's Avatar
MGV156
Michelle, the final product looks sweet! It does look like a lot of work though. I tried clearing out my orange taillights from my Maxima one time but gave up when I cracked the lens. I'm afraid of doing this to the Z because of that incident.
Old Feb 20, 2004 | 01:57 PM
whatever's Avatar
whatever
Veteran
wow, you folks are brave... but with an expert (big-al) around... there is no fear!!
looks great!!!
Old Feb 23, 2004 | 08:14 AM
Z-INCOGNITO
OK... last night was the first time i drove my newly amberless headlight Z in the rain & so far...there's no sign of moisture inside... woohoo...
hopefully michelle's & mike's are good too...
yeah... Al's expertise is where the credits due... thanks again Al
Old Feb 24, 2004 | 06:54 PM
big-al's Avatar
big-al
Default passport
henry, u got PM.
i'm getting mike's passport, let me know so i can pick up same time. thanx
alan
Old Feb 25, 2004 | 12:16 PM
mgl's Avatar
mgl
After heavy rain and a nice carwash. (of course i wash the car then it rains ) no moisture at all. no problems at all. pray it stays this way.
Old Feb 26, 2004 | 08:24 AM
Z-INCOGNITO
Same here... after yesterdays rain... no moisture at all. i think i passed the test already... woohoo
Mike: i won't be able to pick up those bulbs... can u hang on to em for me until i get back from 808 (im there for a week startin tomorrow)... i'll call u up... Thanks
Al: Thanks for the PM... i'll call u about those passport when i get back...
anyone want anything from hawaii? let me know
Old Feb 26, 2004 | 10:52 AM
bz8's Avatar
bz8
Henry, get me a Hawaiian Hoochie Mama !!
Old Feb 26, 2004 | 11:47 AM
Z-INCOGNITO
You got it Tony... but you do know there's some in SF already... goto OFarrell or Centerfolds...
That's what i just heard!!!
Old Feb 27, 2004 | 10:16 AM
  #38
MDubbsZ's Avatar
MDubbsZ
no problem, let me know when you get back.
Old Mar 24, 2004 | 03:08 PM
  #39
Anthony Mantovani's Avatar
Anthony Mantovani
I'm thinking of doing this with a couple of friends at their shop, What bulbs are you using for the parking lights and where the orange strip is? Are they white or blue, in the pics, they seem to have a bluish tint. Also what bulb did you use for the front/rear turn signal? does it light clear or amber? Thanks guys
Old Mar 25, 2004 | 01:55 AM
  #40
Trustd_1's Avatar
Trustd_1
mgl,
great job on the job and esp. for taking the time to chronicle the whole process w/directions and pics!!
I've never done a set of 350z lights, but this mod is pretty popular among other car enthusiasts too (RSX, Civics, WRX's, and others). Anyways, here's a couple things that might be helpful for others wanting to try the mod:
--instead of using a heat gun, you can also soften the factory sealant by baking your headlight housing (yes, really!!) Im sure quite a few of you already know this, but it's pretty simple using this method. Just set the oven to 200-225 deg (NO HIGHER) and warm for like 7-10 mins...more if required. Then follow the posted directions for disassembling and removing the turn signal strip. Using the oven method is a little easier than employing a heat gun because the heat is evenly distributed around the housing, and you don't have to worry about getting hot spots, due to concentrating the heat too much on certain points.
--Like mgl commented, be careful not got touch the chrome inner housings or get lint and other contaminants on them or else they'll show up when you reassemble the lights and look YUCKY!! If you get some smudges or other gunk on the housings, use Windex or better yet, some rubbing alcohol to clean the surface. Use a lint free paper towel or microfiber towel to further prevent contaminating or scratching the housings. If you have it available, a final prep could be done w/a can of compressed air (like for cleaning computers) or an air compressor.
--Finally, it's probably also covered in another thread, but you can take the headlight mod one step further and black out the chrome housings using high temp sprap paint....gloss, flat, semi-gloss, body color--if you're feeling ricey! A couple coats will do. Just make sure to allow each coat to dry before adding another one and all of them to cure before reassembling the lights. Oh, and prep the housings w/rubbing alcohol to ensure optimal paint adhesion/durability.
Hope this helps!
