Orange Strip Removal Guide
Old Feb 19, 2004 | 08:43 PM
mgl's Avatar
mgl
Default Orange Strip Removal Guide
Supplies needed:
Heat Gun
Sealant (black silicone)
Screwdrivers
Duct Tape
Someone to help you.
Step 1: Remove the front bumper and take off the headlights
Step 2: Cover the headlights lenses with duct tape
Old Feb 19, 2004 | 08:46 PM
mgl's Avatar
mgl
Step 3:
slowly heat up the seams of the headlight.
becareful and avoid over heating
(beware of "wet spots" = when the plastic starts to get shiny and looks like there is condensation forming.... if this occurs quickly redirect the heat gun to a different section of the headlight)
Old Feb 19, 2004 | 08:48 PM
mgl's Avatar
mgl
after 15 mins of heating the seams.... unscrew the small gold screws that hold the light together.
Old Feb 19, 2004 | 08:49 PM
mgl's Avatar
mgl
total heating time is appoximately 25-30 mins (depending on the heat gun)
Old Feb 19, 2004 | 08:51 PM
mgl's Avatar
mgl
Step 4:
After heating, use a screwdriver to pry open the headlight.
Old Feb 19, 2004 | 08:54 PM
mgl's Avatar
mgl
once the headlight is open.... have your helper hold and stabilize the headlight while you pull the lenses off the headlight. do this carefully and slowly. if the glue is not softened enough from the heat, you will have to reheat the seams.
Old Feb 19, 2004 | 08:57 PM
mgl's Avatar
mgl
so your headlight should look like this:
Old Feb 19, 2004 | 09:00 PM
mgl's Avatar
mgl
Step 5:
without touching the inside of the lense. carefully unscrew the screws hold the chome piece to the lense. and the entire chome piece should now able to remove
Old Feb 19, 2004 | 09:02 PM
mgl's Avatar
mgl
with the chrome piece out (do not touch the faceside of the chrome piece).
hold the chrome piece from the back and using a small screwdriver, pop out the orange reflector strip
Old Feb 19, 2004 | 09:04 PM
mgl's Avatar
mgl
once the orange strip is out. carefully put the chome piece back into the lense. (becareful not to get any of the black glue onto the chrome piece)
Old Feb 19, 2004 | 09:07 PM
mgl's Avatar
mgl
with the chrome piece back in place...... hold the lenses with the duct tape up and have your helper spray the inside to remove all or any lint or dust that may be there.
Old Feb 19, 2004 | 09:08 PM
mgl's Avatar
mgl
do the same to the headlight unit
Old Feb 19, 2004 | 09:10 PM
mgl's Avatar
mgl
with both the lense and the headlight unit clean from lint or dust.
carefully put the lense back onto the headlight unit.
unmask the duct tape on the sides to ensure that no glue was accidently transferred to any part of the chrome.
Old Feb 19, 2004 | 09:13 PM
mgl's Avatar
mgl
reheat the seams and squeeze the seams together
Old Feb 19, 2004 | 09:18 PM
mgl's Avatar
mgl
reheat the seams for 2-5 mins
Old Feb 19, 2004 | 09:22 PM
mgl's Avatar
mgl
rescrew the small screws that hold the headlight together. make sure the plastic clips on the sides are intact.
Old Feb 19, 2004 | 09:23 PM
mgl's Avatar
mgl
heat the backside of the seams and squeeze together
Old Feb 19, 2004 | 09:27 PM
mgl's Avatar
mgl
remove the duct tape off the lense.
using acrysol on a paper towel. wipe off the sticky residue of the tape. once all the residue is removed. re-wipe the lense with windex.
Old Feb 19, 2004 | 09:30 PM
mgl's Avatar
mgl
using the sealant. seal the seams up to prevent moisture /condensation inside the headlight.
Old Feb 19, 2004 | 09:31 PM
mgl's Avatar
mgl
make sure to get enough sealant around the headlight.
