Not Z Related Items Post your items for sale here that are not Z-related.
FS: Boston Acoustics BT1 Loudspeakers Retails for $800 each
Old Jul 8, 2012 | 07:52 PM
mrberliner's Avatar
mrberliner
Default Boston Acoustics BT1 Loudspeakers Retails for $800 each
Up for sale are 3 MINT condition Boston Acoustics BT1 Loudspeakers
These are very high quality speakers and are perfect for any home theater setup!
Description:
The Boston Acoustic BT1 LCR Loudspeaker is designed for installation inside A/V cabinetry or a theater stage and offers performance and installation ease. It's ideal for use as a left, center or right channel in a home theater system or in stereo music applications. This speaker features a VR high-output 1" aluminum dome tweeter, 4.5" neodymium midrange driver, and a 8" neodymium woofer with a die-cast basket for powerful bass.
Each aspect of this speaker has been carefully thought out. Die-cast finger-pulls positioned at the front of each speaker enclosure allow easy installation in tight cabinet spaces, supplied neoprene pads prevent scratching and allow for smooth slide-in positioning of the speaker. All cable input terminals are recessed, and the height of the BT1 speaker is a standard component size of 17.5 inches.
The midrange and tweeter baffle can rotate 360 degrees for horizontal or vertical placement in cabinetry -- maintaining the proper sonic vertical alignment of the midrange and tweeter. The baffle can also be angled for more accurate imagining when the speaker is far off-axis. Made from ridged die-cast aluminum, the baffle's thermal mass provides tremendous heat dissipation for the midrange and tweeter.
Once installed, the BT1 speaker music and cinema speaker should provide you with years of stunning audio performance.
Designed for installation inside A/V cabinetry or a theater stage
Ideal for use as a left, center or right channel in a home theater system or in stereo music applications
Features a VR high-output 1" aluminum dome tweeter, a 4.5" neodymium midrange driver
Powerful bass is delivered by one 8" neodymium woofer with a cast basket
Neoprene pads prevent scratching and allow for smooth slide-in positioning of the speaker
Recessed cable terminals; height of the speaker is a standard component size of 17.5"
Ridged die-cast aluminum baffle's thermal mass provides tremendous heat dissipation for the midrange and tweeter
Midrange and tweeter baffle can rotate 360 degrees for horizontal or vertical placement in cabinetry; maintains the proper sonic vertical alignment of the midrange and tweeter
I am asking $500 OBO for each speaker and I have 3 available.
Old Jul 12, 2012 | 10:20 PM
mrberliner's Avatar
mrberliner
bump
allmycarsdie
May 13, 2016 04:38 PM
Nihsnek
Feb 9, 2016 12:57 AM
taywan
South East Marketplace
33
Dec 12, 2015 09:05 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
Anyone2u
Audio Builds
Dec 3, 2002 03:09 PM
