Not Z Related Items Post your items for sale here that are not Z-related.
FS: SureFire Vampire V2 150lumen Flashlight
Old 07-06-2015, 04:12 PM
sofakiing
sofakiing's Avatar
Arrow SureFire Vampire V2 150lumen Flashlight
'Used' but i use that term loosely since i used my other SureFire for work and this just sat around the house.
Blind your neighbor from a mile away & be super tactical!
http://www.surefire.com/v2-vampire.html
V2-BK
The V2 Vampire is a compact dual-output flashlight that provides both white light and infrared output—without the need for an IR filter. This groundbreaking illumination tool features a virtually failure-proof power-regulated white/infrared LED assembly and a precision Total Internal Reflection (TIR) that focuses both white and IR beams in optimal configurations.
In white light mode, the V2's tactically correct two-stage pushbutton tailcap switch lets you instantly select an output level: press for a 10-lumen long-runtime low beam suitable for general night use; press further for a 150-lumen white spot beam — more than enough light to temporarily blind and disorient an aggressor by impairing his night-adapted vision. Twist the tailcap for constant-on low beam, twist further for constant-on high beam.
A push-twist on the V2's self-locking selector ring lets you switch to infrared mode, where the tailcap switch again lets you instantly select output levels—press for a 10-milliwatt low beam, press further for a 120-milliwatt high beam. Twist the tailcap for constant-on at either level.
The V2 Vampire features a lockout tailcap, which prevents accidental activation during storage or transport.
The V2 runs on two 123A lithium battery, is constructed of aerospace aluminum that’s Mil-Spec hard anodized for extreme durability, and is 0-ring and gasket sealed to keep out moisture.
[NSN: 6230-01-588-2315]
Features
White and infrared output from one all-LED head, no IR filter needed
Virtually indestructible LED emitters regulated to maximize output and runtime
Two output levels — high for maximum light, low for extended runtime
TIR lens produces tight beam with enough surround light for peripheral vision
Coated tempered window resists impact, maximizes light
High-strength aerospace aluminum body, Mil-Spec hard-anodized for extreme durability
Two-stage tactical tailcap switch — press for momentary-on low, press further for high, twist for constant-on at either level
Heavy-duty stainless steel clip provides multiple carry options
Weatherproof O-ring and gasket sealing
Includes high-energy 123A batteries with 10-year shelf life
IMG_7414 by sofa king, on Flickr
IMG_7411 by sofa king, on Flickr
IMG_7410 by sofa king, on Flickr
IMG_7409 by sofa king, on Flickr
IMG_7408 by sofa king, on Flickr
$220 shipped obo
sofakiing is offline
Flo-ridaZ33
Not Z Related Items
03-14-2011 11:04 AM
dchengmd
11-08-2003 09:26 PM
Quick Reply: FS: SureFire Vampire V2 150lumen Flashlight
