Injected Performance releases rear differential brace!
Old Sep 6, 2009 | 03:03 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by Glex25
I'm hoping it fixes my problem with wheel hop when I loose traction going straight.
I mostly do road course also.
There are various ways to minimize wheel hop -- start with technique.
Old Sep 6, 2009 | 03:15 PM
Glex25's Avatar
Glex25
Granted that statement maybe be true as far as lowering dampening rate and possibly using lower spring rates. My problem is when I'm trying to stay in the mid-upper RPM band and the road course is wet and I push on the gas and all I get is wheel hop.
Countless time with solid diff bushings and other types of braces on numerous Independent Rear Suspension cars have proven to greatly improve minimize these characteristics.
Old Sep 8, 2009 | 07:43 AM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
Originally Posted by oro
Would this be an equivalent alternative to a solid diff bushing or something to be used in conjunction with it?
For the average street car, I would say that it would be an equivalent alternative. For someone looking to reduce wheel-hop in as many ways as possible, doing both may yield an additional advantage. We have tested these already on the street and on the drag strip, but not yet in a road course situation where there is wheel hop on corner exit.
Another benefit to keep in mind is the added support for the diff itself. Normally, there is just one bolt to secure the diff. We have seen forum posts where that bolt has actually broken. Adding the brace gives a bit more peace of mind for the higher horsepower guys who don't want to risk something like that happening.
Old Sep 8, 2009 | 12:02 PM
forced_04's Avatar
forced_04
off the line will this make any difference for wheel hop?
I can imagine the torsion created under hard launches would lead to wheel hop and this would suppress it thus reducing wheel hop correct?
I know to eliminate it requires suspension but does this reduce it at all?
Old Sep 8, 2009 | 12:11 PM
Motormouth's Avatar
Motormouth
this uses the hole already in the subframe, correct? I seem to recall there being one.
Old Sep 8, 2009 | 12:20 PM
forced_04's Avatar
forced_04
pretty sure it does, IP said that it doesnt require any modification to fit, that it utilizes stock mounting points. Plus I remember that hole.
Old Sep 8, 2009 | 12:35 PM
Glex25's Avatar
Glex25
Can't find the hole if it ain't got hair
Old Sep 9, 2009 | 05:29 AM
InjectedPerformance
We've seen improvement in the amount of wheel hop on launching in our usage so far, but it's such a difficult thing to measure objectively that I can't say it will give an x% improvement or anything. It does significantly stiffen the rear diff, which in turn, will reduce the amount of vibration that the axles see as well. Even in street driving, without hard launches off the line, there was a difference.
Old Sep 9, 2009 | 09:34 AM
aarantes's Avatar
aarantes
How many do you guys have left I don't get payed for another week
Old Sep 9, 2009 | 09:49 AM
Snow-G's Avatar
Snow-G
Old Sep 9, 2009 | 10:38 AM
InjectedPerformance
We quickly sold out of our initial batch, but more are currently being made. They should be ready for shipping by the end of this week, and we plan on having plenty available
Old Sep 9, 2009 | 11:20 AM
str8dum1's Avatar
str8dum1
So i got my brace. Simple install. Only thing that concerns me is that the aluminum subframe it mounts to is just a hollow box. The more you tighten it down there, the more is pinches in the box. Makes you wonder how much support it really gives as that hollow box is easy to flex. Headed to the track tonight if the weather holds out.
Either way, here are some pics... pretty much the same as the ones IP posted.
Old Sep 11, 2009 | 10:23 AM
InjectedPerformance
Thanks for the pics! Let us know what you thought about it if you were able to make it to the track.
Second batch is currently being powdercoated and should start shipping early next week.
Old Sep 13, 2009 | 04:35 AM
str8dum1's Avatar
str8dum1
I made 3 changes to the car all at once, so its hard to quantitate its specific impact. Either way, no wheel hop, and dropped over 1/2s off my 60'
The only concern i have now if jacking the car on the rear diff. Thats how i quick change my rear tires. Before the rear diff would compress teh mounting busing some. now its rigid.
does that mean that all the weight it being taken buy that aluminum box since that diff bushing isnt compressing?
Old Sep 13, 2009 | 09:28 AM
3hree5ive0ero
Retired Admin
^^ I would assume so.
Also, if you dropped over .5 seconds in your short time, you needed a LOT of work to begin with, regardless of tires, power, etc.
Old Sep 13, 2009 | 03:37 PM
str8dum1's Avatar
str8dum1
not really as 2.1 is pretty good on street tires. my 1.68 on DR's was pretty good as well.
i just dont wanna elongate that aluminum hole that the brace mounts through. it would take quite a bit longer if i had to jack one side at a time
Old Sep 14, 2009 | 06:25 AM
Dynosty's Avatar
Dynosty
I would recommend using the factory jack points, but fwiw I have raised my personal Z by the dif many times to switch tires since installing the brace and have not had a problem.
I did not have a wheel hop problem before, so I can not comment on an improvement there as I still don't have any. There was a very noticeable reduction in the drivetrain chatter/shaking that occurs with a grabby clutch (such as the Tilton I run).
Old Sep 14, 2009 | 07:17 PM
  #38
OldManZ350's Avatar
OldManZ350
I have one on order, are they ready to ship?
Thanks.......
Old Sep 15, 2009 | 06:47 AM
  #39
InjectedPerformance
Thanks.......
Checked in this morning with our powdercoating shop across town, and they are in the process, but not quite ready to let them go yet. It shouldn't be much longer, but their lead times tend to fluctuate. I apologize for the delay; you are not alone
If it is urgent, shoot me a PM or call me and we'll see what we can do for you today.
Thanks,
Ryan
Old Sep 15, 2009 | 10:16 AM
  #40
OldManZ350's Avatar
OldManZ350
Thanks,
Ryan
NOT urgent, just wanted to know when it was coming.
Thanks.......
