10 Easy Steps To Headlight Restoration
Old May 1, 2011 | 03:43 PM
starbuck's Avatar
starbuck
I just bought the 3M headlight restoration kit ($24 at Autozone). It comes with the 3000 grit pad and a lot of other things. The reason I purchased it is because I have scratches on my headlights. However, you can't feel the scratches from the outside so I'm assuming they are on the inside of the plastic?
Is there any way to buff them out if they are truly on the inside? Also, how would I know if they are on the inside instead of the outside (I realize this might be a stupid question to ask but I don't know how scratches would form on the inside of the plastic....heat perhaps?)
Thanks
Old May 3, 2011 | 08:24 PM
BigD2k5's Avatar
BigD2k5
Thanks
The insides will not be damaged unless someone had them apart at one point and abused them. The scratches you have are probably on the outside but so minor that you just cannot feel them. Sometimes you can look ALONG (or parallel to) the lens' curvature while your headlights are one. Many times you will see all of the scratches and verify which side they're on. Another thing you may be seeing is "crazing". They might look like tiny web-like cracks. This is caused by temp changes (mostly heat) being greater than what the plastic can withstand. I've seen one set of Z lights so severe, the cracks were half way through the thickness of the plastic. Let me know if you have any more questions.
Old Aug 7, 2012 | 11:34 AM
bigbirdmodeZ's Avatar
bigbirdmodeZ
Question
Can you repair these cracks? Don't know if this is 'crazing' or just small cracks?
Last edited by bigbirdmodeZ; Aug 7, 2012 at 11:34 AM. Reason: this is after I've used the Meg's restore kit.
Old Oct 26, 2012 | 07:45 AM
bigbirdmodeZ
Question
bump, would like to know some opinions on the spider cracking from my picture. Thanks
BG
Old Oct 26, 2012 | 08:03 AM
tcode's Avatar
tcode
Thanks!
Old Dec 30, 2012 | 06:06 AM
350zx6r's Avatar
350zx6r
Question
+2 anybody
Old Feb 2, 2013 | 09:50 AM
nismoracer_206's Avatar
nismoracer_206
[ATTACH]Name:  untitled2.bmp
Size:  41.4 KB[/ATTACH]^^^^^^^^^^^^^^ i as well woud like to know cause min is doing the same thing
File Type: bmp
Old Feb 16, 2013 | 02:29 PM
nismoracer_206
bumb nobody have any ideals on this
Old Mar 11, 2013 | 02:49 PM
ZeeZee's Avatar
ZeeZee
bump +99999999 anyone?
Old May 21, 2013 | 11:32 AM
bullionz's Avatar
bullionz
I use mcguiars ultimate compound on a rag, and rub it in... takes a few mins for both, and they look brand new.
Old Apr 29, 2014 | 05:39 PM
Mark_Rivera55's Avatar
Mark_Rivera55
This is what mine look like it's really bad some people say I can restore but I think I need a new headlight
Old Apr 29, 2014 | 05:40 PM
Mark_Rivera55
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
