Forged Performance: 587whp 350Z Roadster -- Video Inside
Originally Posted by wtf no turbo
ZR is one of the most stout verts ive ever seen. 500hp pull on the highway with the top down.......you can have your roof and 200 pounds
Originally Posted by Beer Goggles
Nice! ALthough I'm slightly confused why people want a ZR when they are going for max power. Roadsters are usually way less rigid, and on the street with that much power isn't ideal. But I know we want to look good too.
There are a # of things that can be done to reduce chassis flexing, but I have to say the car is built pretty well. I do not think it is necessary unless you are going above say, 500whp on the ZR. I think at that point I think any chassis could use some extra help in this department. The benefit the coupes have is, usually at that point they go with full or partial cages. Whereas we with convertibles can’t really do that, so we have to do other things.
It is all good, to each their own. Just like everything else, everyone has their own opinions on what makes a great car. Mine includes the ability to go topless…
--B
http://www.freshalloy.com/site/cars/...ter/home.shtml
Originally Posted by FreshAlloy.com
Structural reinforcements were made, however, to combat the loss of rigidity you normally see when you take the top off of a vehicle. These enhancements include a center floor V-shaped cross bar connecting the side sills and a front A-shaped cross bar reinforcing the front end. Additionally, the doors openings were reinforced, along with a "triple member" added to the seating area connecting the sides to the floor structure to beef up rigidity.
The roadster may be heavier and consequentially slower but enough of the talk about the ZR not having as much "rigidity". Most everyone here couldn't honestly tell the difference.
Thanks everyone. It has been a tough battle going from shop to shop trying to get this car done right and my final stop Forged Performance has finally done it. The perfect engine build, the right mechanics, the right parts, and the perfect tune. I have never been happier. I will say, didnt we make 566whp on pump gas at 15psi sharif?
Forged Performance
Forged Performance
And he does it again congrats Sharif and to sherv. enjoy the ride man...
sharif i think u pushed a lil bit extra with the pump gase and then whent easy with the mix right? other wise ur mix would have been way higher right?
Forged Performance
Forged Performance
And remember, I didnt raise the boost at all for the second runs. We were running out of fuel pump, so I didnt want to push it further. But absolutely, with a stage II fuel system, a full tank of race fuel, and more boost, an additional 100whp is possible.
Since I don't spend a whole lot of time here in the FI forums, I figured I would ask this question in this thread. What factors are holding you back from hitting 700, 800, etc?
-Acree
-Acree
Forged Performance
Forged Performance
-Acree
-Acree
Stage II fuel system is needed beyond the 600whp mark on our dyno (probably 650whp on a dynojet). Beyond about 700-800whp, there are no bolt on turbochargers that will support the needed airflow to reach those numbers. With a larger frame turbocharger then 1000whp should be achievable.
Originally Posted by Sharif@Forged
Fuel and air.
Originally Posted by Zilvia
just curios tho kinda of off the topic. Are their any Supra that run twins in the 700s........
if so what size(kinda) turbos do they run.
I didnt mean a medium frame...I meant a larger turbocharger...I was actually thinking a twin GT35 setup.
