Shop Builds Temp moving posts for some clean up of this section.
*** GT Motorsports 4.24L Stroker Kit Preliminary Dyno Results ***
Old Feb 6, 2007 | 06:50 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Default *** GT Motorsports 4.24L Stroker Kit Preliminary Dyno Results ***
In the last few weeks we have been anxious to complete the first pair of GTM stroker kit cars, mated with different stage heads. Additionally, different components were tried, including fuel injectors, intake manifolds, exhaust systems, and more. Here we present our accomplishments so far.
I would like to first start out by apologizing for the lack of updates over the last few weeks. Please rest assured that we have been hard at work nailing down the various issues, focusing on the soundness of the car as a whole and in turn its expected longevity rather than merely producing big HP/TRQ numbers (which was in our minds a certain thing). Second, I would like to thank all of our customers that purchased these stroker engines (without a sigle dyno result as of yet), relying solely on our reputation. We indeed greatly appreciate it.
Here are the two completed strokers currently in our shop.
4.24L Engine/Car #1 ('05 350Z RevUp)
FI: APS Extreme Twin Turbo Kit (50lbs/min turbos)
50 Short Block: GTM 4.2L stroker short block
Heads: GTM Stage 3 heads (1mm oversize valves)
Cams: JWT S7 cams
Studs: GTM 12mm head studs
HG: Cometic head gasket
Valvetrain: Ferrea single springs/Ti retainers
Fuel system: APS Extreme Fuel system
Cooling: Nissan Pathfinder mod, Koyo radiator, dual oil coolers (oil/power steering fluid)
Intake: Nissan OEM
Clutch: GTM Spec/Exedy Twin Plate Carbon
Red line: 7000rpm
EMS: HKS Fcon Vpro
4.24L Engine/Car #2 ('06 350Z RevUp)
Heads: GTM Stage 4 heads (1.5mm oversize valves)
Cams: GTM RevUp cams (prototype)
Valve train: Ferrea single springs/Ti retainers
Fuel injectors: HKS 1000cc
Fuel system: CJ Motorsports Dual Pump (prototype)
Cooling: Nissan Pathfinder mod, PWR custom radiator, dual oil coolers (oil/power steering fluid)
Intake: Motordyne Engineering MREV Isothermal (5/16” spacer)
Clutch: GTM Spec/Exedy Triple Plate Carbon (prototype)
Red line: 8000rpm
EMS: HKS Fcon Vpro
Dynamometer results:
Each of the following charts were obtained from the Engine/Car #1
Dyno #1
612whp / 581lb-ft trq @ 12psi 93 octane (13gal of 91 octane AND 7gal of 100 octane)
Very conservative Fuel and Timing
Dyno #2
633whp / 614lb-ft trq @ 13psi 93 octane (13gal of 91 octane AND 7gal of 100 octane)
Again, very conservative Fuel and Timing
We will be switching to pure 105 octane tonight and then C16, on to our 24psi destination! Given the compressor flow maps and how well these turbos fit the 4.24L configuration, there will be no efficiency loss in going to those boost levels. This Turbo kit/4.24L stroker is an winning combination. And remember, this is still ONLY 12-13 PSI.
The car feels extremely stable in all aspects.
Old Feb 6, 2007 | 06:57 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
HOLY CRAP! Nice to see the Rev up reppin. These are some amazing numbers. Only wish I had unlimited funds.
Old Feb 6, 2007 | 06:59 PM
MIAPLAYA's Avatar
MIAPLAYA
First congrats on the excellent job and excellent power production so far. A question, does the peak torque value directly correspond to the boost threshold (peak boost engine speed)? Also will both engines and fuel systems be tested to the same pressure ratio? Thanks!
Edit: Could you post the boost curve..
Old Feb 6, 2007 | 07:01 PM
Mike Wazowski's Avatar
Mike Wazowski
nice numbers. I cannot wait to get my car to you.
Old Feb 6, 2007 | 07:05 PM
TENGAI's Avatar
TENGAI
Great work Sam. I'm really curious to see what happens with engine #2 and 24psi... I'm betting 850+whp. Amazing what's starting to happen with these engines. Again, congrats on yet another milestone.
Old Feb 6, 2007 | 07:07 PM
tig488's Avatar
tig488
freakin sweet numbers, i cant wait for the 24psi results,
lot of mulla tho, youre talking 25K give or take a few! i guess thats not too bad, considering the supra packages are pretty high as well.
ct350z's Avatar
ct350z
what numbers will you be expecting on higher boost, say 14-16lbs?
Old Feb 6, 2007 | 07:08 PM
monokuroboo's Avatar
monokuroboo
CHRIS (350) FTL
F*ck 380 RS, 3xxz, whatever.
420zTT.<3
Old Feb 6, 2007 | 07:17 PM
Changvi's Avatar
Changvi
Wow, very nice numbers... What would a NA 4.2 stroker putting to the ground?
Old Feb 6, 2007 | 07:24 PM
Nitrouz's Avatar
Nitrouz
Back to Z
Amazing...would love to see 24psi on car#1.
ML2000's Avatar
ML2000
Wow Sam great work.
Old Feb 6, 2007 | 07:28 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'll have one of those, please.
Old Feb 6, 2007 | 07:32 PM
Nihilation's Avatar
Nihilation
I'm interested as well.
Old Feb 6, 2007 | 07:35 PM
Vick781's Avatar
Vick781
The owner of that z is a lucky ****
Old Feb 6, 2007 | 07:46 PM
Dubai's Avatar
Dubai
Impressive...I bet at 24psi you'll hit the 900whp mark.
Old Feb 6, 2007 | 07:50 PM
Chineseguy's Avatar
Chineseguy
i would love to see that engine.
Old Feb 6, 2007 | 07:55 PM
z33boi's Avatar
z33boi
those are awesome numbers, keep it up
Old Feb 6, 2007 | 07:59 PM
o snap its eric's Avatar
o snap its eric
+1 on the 4.2l on a NA setup and on a non rev'ed up motor.
Old Feb 6, 2007 | 08:01 PM
plumpzz's Avatar
plumpzz
videos! now!
Old Feb 6, 2007 | 08:11 PM
thawk408's Avatar
thawk408
Is the power falling off before redline due to timing?
