Shop Builds Temp moving posts for some clean up of this section.
Function:Tuned - 3.8L N/A Build Auto Tranny!!
Old Apr 22, 2009 | 03:44 PM
Mr_pharmD's Avatar
Mr_pharmD
Not sure if all the parts listed will make the most whp out of this NA setup. There are better headers and intake plenum in the market but the problem is the auto tranny... but who knows, u might get lucky and see low 300s on race gas.
Old Apr 23, 2009 | 07:00 AM
rrmedicx's Avatar
rrmedicx
Nitrous? Maybe?Please? Or else this build is serious overkill. Just sux to see so much money spent for such little power IMHO.
.....To each his own though.
Old Apr 23, 2009 | 10:17 AM
tylerxfire's Avatar
tylerxfire
cool, but really not the smartest move
Old Apr 23, 2009 | 01:05 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Very peculiar and questionable build list for maximizing an NA setup. Is this what the customer wanted, or did you recommend this combination of parts? Or is it a little of both?
Why no headwork??? And the JWT C2 cams are a weak choice IMO. But most of all... Please tell me you're not using a Kinetix SSV!!! If so... WHY?!?!?!?!??? That thing has been shown to be a piece of crap for NA applications. Like most folks, I lost power with mine. I immediately went back to the stock plenum and later added a PowerLab spacer.
Old Apr 23, 2009 | 01:17 PM
MikeFunction2nd's Avatar
MikeFunction2nd
Vendor - Former Vendor
Everything on this build list was at the request of the customer!!
Old Apr 23, 2009 | 01:23 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
OK, that explains it. Too bad you or Dave couldn't talk some sense into him. What a waste of potential for a 3.8L sleeved block IMO.
Old Apr 23, 2009 | 01:39 PM
0jiggy0's Avatar
0jiggy0
sucks you couldnt convince him to better use his resources.
Old Apr 23, 2009 | 02:17 PM
__jb's Avatar
__jb
Z + Rear Seat
I was wondering about the 3.8L too and didn't see anything about a crank. Interesting that he chose to do a 100mm bore instead of a stroker crank. I thought about going 100mm but got scared of the sleeves. It will be interesting to see how this motor performs. Should make good power.
Someone move this to the "N/A Build" forum before all the FI people infect the thread.
Old Apr 23, 2009 | 06:56 PM
DanielW's Avatar
DanielW
wow, I really don't see the point in this build at all. But to each his own i guess. Maybe the owner is saving up for monster heads?
Old Apr 29, 2009 | 12:52 PM
abui01's Avatar
abui01
Some people would rather max out N/A than slap on a turbo. I could understand where he was going with this because this is exactly what I did 9 years ago =)
Old Apr 29, 2009 | 03:01 PM
DanielW's Avatar
DanielW
yeah but in this case "maxing out" NA is only going to have minimal hp gains and is going to cost him an amount of money that A.) could've put him into a completely different league of car or B.) could've easily given him a TT beast
Old Apr 29, 2009 | 05:54 PM
rcdash's Avatar
rcdash
I thought the HR had smaller ports than DE heads. Something about keeping velocity up. Let's see how it turns out before making judgments on the build... Good luck guys.
Old Apr 29, 2009 | 08:47 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
You lost me Raj. Where are HR heads mentioned?
Old Apr 30, 2009 | 05:05 AM
rcdash's Avatar
rcdash
I am trying to keep an open mind. Just commenting on the remarks on lack of headwork on this build. I've always been dubious about maximum flow vs maximum velocity at a given rpm that head porting provides. I recall reading that the HR engine (as a point of comparison for a NA build) has intake ports that are actually smaller than DE heads. So perhaps the whole concept of oversized valves is overrated, especially on a NA build. The same rules for FI builds does not necessarily apply. Again, my understanding is that maximizing velocity is more important than FI setups, which can rely upon a high pressure differentials to maximize air flow, regardless of the port size.
Anyway, if it doesn't work, a nice METH setup with some well selected turbos and this thing will be nasty.
Old Apr 30, 2009 | 05:29 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Ahhh, gotchya.
However, it should be noted that thus far the NA guys who have made 300+whp all have headwork and/or aggressive cams.
Old Apr 30, 2009 | 06:11 AM
Clint@Altered's Avatar
Clint@Altered
Mike,
Were you guys (Justice Race Engine do the machining?) able to retain the oil squirters? The bore is really aggressive on a 3.8L non-stroker, same for the 4.15 stroker. We've used 99.5mm JE's a couple times in the past - the skirt was rather long. To retain the oil squirters, we had to clearance the piston skirt on the JEs so they wouldn't hit.
The CPs, If I remember correctly, are shorter - maybe you didnt need to cut the skirts? Or did you guys just scrap the squirters like BC requires for their stroker?
I'm interested to see the power band a 3.8L creates NA. Good luck!
Old Apr 30, 2009 | 03:00 PM
MikeFunction2nd
Yes.. We were able to keep them!!
Old May 3, 2009 | 09:36 PM
  #38
Frostydc4's Avatar
Frostydc4
Interesting build .
The 100mm bore makes sense if you are planning on using more RPM's (I would do this over a stroker, but thats my preference). I would have gone with a better head, cam, and intake manifold setup though.
Keep us posted on the build
Old Jun 10, 2009 | 10:20 PM
  #39
gabe3d's Avatar
gabe3d
Any news on this setup? Thanks.
Old Jun 11, 2009 | 04:52 AM
  #40
MikeFunction2nd
Not as of yet.. still waiting to get the car back in the shop!!
