Shop Builds Temp moving posts for some clean up of this section.
GTM: never too late for another SC kit
Old Jan 5, 2012 | 12:57 PM
Blu_Blur's Avatar
Blu_Blur
Originally Posted by Mike@GTM
We have every intention of getting this kit approved once we finalize the kit. We already have the test letter for the kit, we just have a few minor details we need to iron out with CARB to get it done.
Mike/Sam-
What is this 'test letter' and what does it mean?
Have you guys already done some sort of lab testing with CARB and so far things look good and hence a letter is generated or you have yet to do the lab testing for CARB?
Old Jan 6, 2012 | 10:15 AM
Mike@GTM's Avatar
Mike@GTM
Originally Posted by Blu_Blur
Mike/Sam-
Basically, the test letter is the green light to do the lab testing...one of the final steps for approval. In other words, we're almost there.
Old Jan 6, 2012 | 10:21 AM
Blu_Blur's Avatar
Blu_Blur
Okay. Well the best of luck to you. I've been contemplating the future as I've outgrown my Turbonetics set-up and I've thought about doing a build and matching it with some kind of FI system.
Old Jan 8, 2012 | 06:08 PM
BoomerZ33's Avatar
BoomerZ33
wow this kit is the real deal. sub'd for updates.
Old Jan 24, 2012 | 02:56 PM
ColecatZ's Avatar
ColecatZ
sub'd
wanna cut a deal for a stock block DE dyno?
Old Jan 26, 2012 | 09:36 AM
gabe3d's Avatar
gabe3d
Some delays on GTM's side. The guy that they use to machine the brackets is MIA so they have to find an alternative route. I'm also leaving to Singapore/Korea for 1.5month in two weeks so hopefully by the time I come back things will be peachier.
Old Feb 14, 2012 | 07:27 PM
justboughtaz's Avatar
justboughtaz
Default gTm de, huh?
sub'd!
Old Feb 23, 2012 | 11:44 AM
ColecatZ's Avatar
ColecatZ
Any info to throw out? I would hate to see this die...
Old Feb 26, 2012 | 04:32 AM
gabe3d's Avatar
gabe3d
No new information, still waiting on GTM. Called them last week and they said that they have 3 out of the 4 brackets complete and from there on it's smoother sailing. Still hoping to get it back in March.
Old Feb 26, 2012 | 05:35 AM
Russ@Z1's Avatar
Russ@Z1
Sub'd
Old Feb 26, 2012 | 05:54 AM
e30cabrio's Avatar
e30cabrio
Sorry about the delay. Don't you love some peoples' work ethic?
Old Mar 1, 2012 | 05:43 AM
gabe3d's Avatar
gabe3d
Updated first post. Things are moving along and I'm hoping for the best.
Old Mar 4, 2012 | 10:15 PM
gabe3d's Avatar
gabe3d
Brackets are machine and ready to craddle those extra parts.
Old Mar 7, 2012 | 01:39 PM
ColecatZ's Avatar
ColecatZ
should we expect pretty much identical graphs with the exception of a little more torque?
Being that the DE is maxed out by just about every kit available for it, I'm looking to determine where this will differ...
Old Mar 7, 2012 | 03:18 PM
gabe3d's Avatar
gabe3d
Comparing this to the VHR or HR, the DE will definitely be a little different but it's hard to speculate exactly how much different until the results comes out.
I'm not quite sure what you mean by maxed out by all the kits? There is a guy on here that just recently broke 600whp on his vortech.
Old Mar 8, 2012 | 08:02 AM
ColecatZ's Avatar
ColecatZ
Originally Posted by gabe3d
...I'm not quite sure what you mean by maxed out by all the kits? There is a guy on here that just recently broke 600whp on his vortech...
Sorry, I should have specified.... stock block DE's. Being limited to about 400lb-ft before failure is imminent... some have gone at lower levels than that. With, what is a relatively low ceiling (by todays standards) and a plethora of kits that can punch through that ceiling... what I was trying to get at was specualtion on the pros of this kit over the others for a stock block DE.
Not trying to thread crap at all.... I love seeing a new development for my older platform and I'm stoked that it's coming from GTM, Im just curious what the "ways I'm better" pamplet might read.
Old Mar 8, 2012 | 05:02 PM
gabe3d's Avatar
gabe3d
The only worthwhile SC kit to compare it to is the vortech and you can break it down into two comparisons, the compressor itself and the kit's features. So this is from the top of my head.
Compressor differences
Pros
-quieter compared to any of the vortech ones
-comes with its dedicated oil cooler.
-doesn't share engine oil so doesn't heat up your engine oil (the V3 doesn't share engine oil as well but the V2 does)
-slightly smaller dimensions for a same flowing vortech
-faster build up of boost so much more midrange torque. though from my research this property does change slightly depending on which rotrex model you go with though since it'll shift the pressure ratio a bit.
-check the attached gragh courtesey of crtan77. this is comparing a vortech kit with the HKS kit that has GTS8550 which similar in design to the C38-81 (the one i have is the bigger one, c38-91).
Cons
-first installation on the DE, but GTM has a few on the HR and VHR
-hasn't been around as long as vortech
-not as many good aftermarket options
-less compressor options that are interchangeable
-compressor oil is more expensive then engine oil and the vortech oil, but you seldomly change it out. Regarding that matter the V3 self lubricated one requires a dismount of the compressor to perform the oil service.
Kit comparison
Pros
-Comes with much larger intercooler
-Comes with fuel injectors and pump
-Comes with the reverse cylinder cooling found on the HR (stabilizes the cylinders temp that are closest to the firewall)
-No jack shaft, so only one serpentine belt (but this can also be viewed as a bad thing since you can really customize the drive ratio on the vortech because of this)
-No cog belts
-Compressor is mounted at the bottom closer to the FMIC inlet (less piping and also more stealthy)
-Auto belt tensioner (reduces belt snap)
-Better belt wrap then the vortech
-Air filter location is at a better location and is not sandwhiched
Cons
-more involed installation
-more expensive kit, but much more complete out of the box (so it might turn out cheaper or about the same at the end)
-limited upgrade options in the future for swapping compressor
Maybe Sam or Mike from GTM will add or correct on some of the things I said. HTH.
Attached Thumbnails GTM: never too late for another SC kit-vortech_vs_hks.jpg
Old Mar 9, 2012 | 03:07 PM
  #38
ColecatZ's Avatar
ColecatZ
Very informative post... those are the kind of things I was looking for....especially the improved midrange performance vs the Vortech.
Thank you very much. I'm looking forward to see what comes of this.
Old Mar 10, 2012 | 09:42 AM
  #39
binder's Avatar
binder
-no installation on the DE, but GTM has a few on the HR and VHR
so wait, the first page says this is for the DE. So is this or is this not for a DE platform?
Old Mar 10, 2012 | 01:21 PM
  #40
gabe3d's Avatar
gabe3d
^I should have said none on the DE yet, this is the first one
