Another Daily Driven Vortech Build
Old 05-19-2017, 05:41 PM
  #181
Colombo
Colombo's Avatar
YOU WILL run out of fuel w e85 regardless of injector size, upgrade to a twin pump setup. I am on 93 octane, Walbro 485, a boost a pump and 1300cc and I'm pushing it. On pump. Do it once and do it right w a twin pump or stay pump gas, Would Be dumb to invest all that to run out of fuel on the dyno and end up having to spend more later
Old 05-19-2017, 09:33 PM
  #182
BluestreamDE
BluestreamDE's Avatar
Staisman is running a similar setup to mine on E85 with a CJM S2 and 1000cc injectors and a 340lph pump with 530/460. Although I am noting your comment and considering the twin pump in the future, I find this hard to believe. My fuel pump and injectors will be far surpassed his in flow and he had no issues with fueling from what I read on his thread. He did not have the Twin Pump, and I don't plan to have over 540whp.
Also you run higher PSI than myself, I am only projected to run 16-17psi, while you are making boost in the mid to high 20s.
I made the calculations from this website, https://www.ecmtuning.com/wiki/e85fuel.
A 2000cc injector × .670 (Gas Ratio of E85) = 1340 which is the actual corrected injector flow calculation using E85.
At the very minimum to get 540whp with E85 I would need to have a 914cc flow rate per injector. And if the meth kit is needed, It would me more than enough to help with fueling at WOT with a 11.8afr as well with this current setup. I think I will be fine but I shall see. Thanks for your advise though.
Old 05-20-2017, 05:50 AM
  #183
eZg
eZg's Avatar
Plus it puts more responsibility on the shop that built the engine. That is worth LOT in my opinion. Good luck
Old 05-20-2017, 05:58 AM
  #184
Colombo
Colombo's Avatar
What I'm getting at is why restrict yourself now, you're going through all this effort to limit yourself. Regardless best of luck 👍🏽.
Old 05-20-2017, 08:54 AM
  #185
eZg
eZg's Avatar
Not to speak for OP but after a year of downtime, I personally would be happy to get what I can out of a single pump just to see if new engine is going to allow myself to get the dang thing rolling again. Dude has already spent a shitload of cash. Gotta draw the line somewhere
BluestreamDE (05-20-2017)
Old 05-20-2017, 08:49 PM
  #186
BluestreamDE
Haha, you aren't lying about that brother. I think I will be fine with this setup for now. The CJM Twin pump is a simple remove an replace job I can do myself later once more fuel is needed for my car with a larger blower. Planning on the Ti Trim or V7 Ysi & camshafts in the far future, but for right now I will be happy with the car with whatever it makes on E85, stock head and the 928MS impeller. The Wife wants a trip to the Philippines when I get back, so I gotta save for that as well, can't just spend all my deployment money on the car lol.
Old 05-30-2017, 06:06 AM
  #187
BluestreamDE
Update. Carl Faucett from 928 Motorsports informed me that the blower had some shaftplay and cause minor damage to my impeller.
I ended up just doing another Super Vortech Premium Rebuild (Great, more money spent) so the time to where the car is completely put together and ready to tune on E85 has been pushed to the right slightly. Should take a week and a half to get back to the shop, 485lph Walbro and 2000cc injectors are already delivered, so just waiting on that.
Old 05-30-2017, 10:05 AM
  #188
OldManZ350
OldManZ350's Avatar
Who installed the Impeller?
Old 05-30-2017, 10:36 AM
  #189
BluestreamDE
Carl Fausett did. He did the previous rebuild I did last year.
Old 05-30-2017, 12:49 PM
  #190
Logiqal
Logiqal's Avatar
So then he's fixing his own work and not charging you...I hope.
OldManZ350 (05-31-2017)
Old 05-31-2017, 07:10 PM
  #191
OldManZ350
OldManZ350's Avatar
My friend sent his Vortech into Carl for a rebuild and New Impeller, and when he got it back and installed he found out the the impeller was rubbing the Volute. Carl fixed it, but this cost my friend time and Carl never did say it was their fault.
Old 05-31-2017, 07:47 PM
  #192
BluestreamDE
From what the site said and I Cofirmed thru email, once it leaves their hands, the Warranty expires, so as you can see you can definitely claim it was damaged by the owner and not the business and not take responsibility. I Did not notice any abnormal performance from the blower besides the oil leaking behind the impeller. At this point I will have 3 rebuilds on this blower since receiving it last year. Money that could of went to a bigger vortech...
Maybe the V3 isn't as good and heavy duty as the V2 perhaps.
[EDIT] I was able to reduce the price a little bit instead of paying the entire $1,260 to $1,158 so that is a plus.
Old 06-18-2017, 01:08 AM
  #193
BluestreamDE
Took alot longer than expected but The Premium rebuild by 928 Motorsports is completed and my Vortech is currently enroute to be delivered. Once it gets to the shop, they will continue with the install.
Old 07-21-2017, 09:49 AM
  #194
BluestreamDE
Been over a month, and not much to report. The CJM S2 system is installed up to the fuel pressure regulator. The Kinetix Manifold Mountplate is interfering the port on the right side of the FPR and blocking connection to the rest of the fuel system. Plan is to have the shop cut that extra piece off and relocate where the evap sensor will be placed, a tad lower in the middle firewall. Either I do this or buy different fittings to route the fuel lines differently.
Old 08-05-2017, 03:51 AM
  #195
BluestreamDE
Good news, car is 90% done, but the shop is addressing an issue with their Dyno. Once it's repaired they will slot me in late next week to start tuning on E85, I'm hoping. Ill be sure to spill the beans as I get emailed updates.
Old 09-02-2017, 11:50 PM
  #196
BluestreamDE
Month later no tune, I sent an angry email to the shop expressing my concerns with the length of time this whole process is taking, they told me there was an issue with the fuel pump which has been resolved and is running on its own power.
They also said they were unable to install the 2.87 pulley for some reason. I have not read anything that this pulley needed modifications but they are unable to do it which pissed me off more. Either way my redline will be bumped to 7100 so I should see around 15 psi max.
They also replaced my battery. They are finalizing the last checks with the car making sure it's running properly heat cycling the motor and checking for mechanical errors or leaks. They said they will begin tuning on the 10th with baselines and should be done by the 15th with the WOT tables adjusted.
Picture below is the bay as it sits now since Friday. CJM fuel system is completely installed and operating normally.
Old 09-17-2017, 10:13 PM
  #197
BluestreamDE
This was last week Friday on the dyno finally to start tuning this rebuild on E85 but had issues with my old Uprev Dongle, which I had to pay for another one again. Im waiting on it to be shipped (Should arrive tueday) and brought over to the shop to finally see some numbers after 9+Months of trial and error...
Old 09-18-2017, 05:33 AM
  #198
eZg
eZg's Avatar
Good Luck!
You certainly seem to get more than your fair share of delays with your build. Damn
BluestreamDE (09-18-2017)
Old 09-18-2017, 06:02 AM
  #199
BluestreamDE
Thx! Ohh, You have no idea lol. But the journey is the reward.
Old 11-01-2017, 09:39 PM
  #200
BluestreamDE
2 months later, flying home tomorrow from deployment and my Z ain't done yet. There has been issues with the fuel return system not lowering fuel pressure at idle to 38-40psi. The Fuel lab FPR's that came with the CJM S2 kit has an orifice that is too small for the return line and pressure won't go down lower than 50psi with the big ole Walbro 450.
Had to buy a Aeromotive FPR instead. Shop already has it but I don't think this is the issue. Usually the orifice is the same size in usually all fuel pressure regularlors. Maybe contamination of the fuel or dirt effected the Fuel lab regulator since it's been sitting for almost a year.
This had been a pain with this shop. I think I have the championship for the longest running wait time for a rebuild on this site. But I am trying to he optimistic about it getting done before Thanksgiving at ***ing least...
