Tuning Reflashes, Piggybacks, Standalone ECUs
Osiris from Uprev
Old Mar 6, 2009 | 09:35 AM
  #1501
UpRev's Avatar
UpRev
Originally Posted by Jay'Z
Hey UPREV, I was wondering if you have expanded your shop? Have yall gotten bigger? I was last there in 07 I think, and you didnt have the dyno yet..
We've had our dyno since sometime in 07, so you must have just missed it. We're now in 3 units with two 2 post lifts, and a 4 post lift. Full time tech, a sales/marketing guy, and a part time developer all added to the staff. Along with something like 12 Pro Tuners in the last 5 months, and a Dealer.
So we've grown a bit :-)
Old Mar 7, 2009 | 04:38 AM
  #1502
twitch579's Avatar
twitch579
Originally Posted by drew313
I recently cleaned the throttle body on my 2004 G35 Coupe 6MT and after putting everything back together, my car began idling pretty high around 1100-1400 RPMs. It threw a P0507 code. I tried the manual Idle Air Volume Learning procedure and although it would adjust the idle, it wouldn't keep that setting after I shutoff and restarted the engine. I thought the throttle body may have gone bad so I swapped it out with a new one but still have the same problem. I took it to the dealer and they couldn't get the idle to set with Consult either.
My question is, could the Osiris flash prevent the ECU from relearning the idle correctly? Has anyone encountered this problem before?
Just reflash the car with the most current Uprev map and it will correct your idle.
Old Apr 21, 2009 | 01:20 AM
  #1503
skaterbasist's Avatar
skaterbasist
To the UpRev guys,
I'm sorry if this has already been addressed, but if I do the non-foulers to fix the CEL light caused by test pipes, will this skew the A/F ratio results from the stock wideband sensors in my 2006 G35 Coupe 6MT (revup)?
I've been pondering in installing non-foulers to remove the CEL light. I had my car tuned by Shawn Church automotive with great results. But I wish to start doing some data logging via the Cipher (don't have one yet). And im concerned that installing non-foulers might render the AF readings useless.
Another question I had in mind:
SC tuned my car with 5 maps. As I understand, I can permanentaly change the idle on my car via the Cipher. If my car is already tuned, can I change the idle via the Cipher without any problems? If I do this, will I have to change the idle for each map? Or will changing the idle settings via the cipher affect all maps?
My idle has previously been set to 850 via the cipher from another member. And it seems to me that my idle is still the same after the custom maps. But its just a question I had in mind in case I decide to change the idle settings on my car.
Thanks!
-Henry
Old Apr 21, 2009 | 08:15 PM
  #1504
Aced16's Avatar
Aced16
Hey Uprev, Dont know if this has been talked as this is a rather LONG tread, but hows does Osiris work with Nitrous? right now i am running a UTEC with plans to switch to Osiris. thank you!
Old Apr 22, 2009 | 08:48 AM
  #1505
BiGGD198's Avatar
BiGGD198
many have said osiris with nitrous is a dream come true....i shall let you know within the month....im just bout to finish hooking mine up and tune.
Old Apr 22, 2009 | 11:47 AM
  #1506
__jb's Avatar
__jb
Z + Rear Seat
The lower o2 sensors are used to determine the effectiveness of the catalytic converters.
They don't alter/adjust the air/fuel mixture at all.
I would set the idle range back to zero (0) in Cipher before adjusting it in Osiris.
Idle is a static value in the ROM file. You can't have different idle settings for different maps.
I would expect the Cipher idle adjustment to override the idle settings in the ECU because that is how the Consult II is designed to be used.
Old Jun 4, 2009 | 10:27 AM
  #1507
BakaN20's Avatar
BakaN20
Is there any way you can incorporate an led indicator of which map you are on, just something that says 1, 2, 3, etc. I just want to make sure I am in the right map before blasting a whole bunch of nitrous and realize the map i was on didn't have timing pulled. Just a thought, lol.
Old Jun 4, 2009 | 10:45 AM
  #1508
350z 6spd's Avatar
350z 6spd
You press the accel/decel toggle switch down while simultaneously pressing cancel for the map number you want (ex. press cancel 2 times and you are on map 2, etc...). This is confirmed when the "set" light blinks "x" amount of times for the map you are on (the light will blink 3 times after you have selected map 3, etc...).
Old Jun 6, 2009 | 07:34 AM
  #1509
OCG35's Avatar
OCG35
Nice UpRev Osiris ad in Nissan Sport Mag (pg 43)
Old Jun 8, 2009 | 10:18 AM
  #1510
Netacoma2003's Avatar
Netacoma2003
Had my "emissions" map loaded on Tuesday and passed the test on Friday.
Osiris continues to impress
Old Jun 10, 2009 | 01:15 AM
  #1511
SpeedDemon20's Avatar
SpeedDemon20
Ok so far i have an Intake, cat back, Plenum Spacer and Test pipes. What do i need for a tune. I wanna gain like 10whp. Im ready for a tune or a flash or whatever u call it.
Old Jun 10, 2009 | 08:09 PM
  #1512
Manjot's Avatar
Manjot
Sounds ready to go.
Old Jun 10, 2009 | 09:02 PM
  #1513
SpeedDemon20
What do i need now? The flash or the standard one?
Old Jun 10, 2009 | 09:14 PM
  #1514
03threefiftyz's Avatar
03threefiftyz
flash + dyno tune.....I think xact (sp?) tunes osiris in AZ.
Old Jun 10, 2009 | 10:58 PM
  #1515
SpeedDemon20
How much is the flash? I thought i didnt need a tune if i just get the flash...??
Old Jun 15, 2009 | 08:08 PM
  #1516
Chef-J's Avatar
Chef-J
Booooosstt!!
Tune is what reflash or dyno tune or either.
If you are in N/A, just do reflash your ECU via osiris is way to go and best option. You don't need to do dyno tune unless you going FI or serious N/A build.
www.uprev.com has price for reflash ECU via osiris.
Old Jun 15, 2009 | 11:09 PM
  #1517
SpeedDemon20
i dont want to send my ecu in tho.
Old Jun 16, 2009 | 04:16 AM
  #1518
350Zenophile's Avatar
350Zenophile
You should get a good cup of coffee and just start from page one of this thread...enlightenment will be yours.
Old Jun 18, 2009 | 11:07 AM
  #1519
biggersNISMO's Avatar
biggersNISMO
Any pro tuners near Colorado?
Old Jun 18, 2009 | 01:16 PM
  #1520
__jb's Avatar
__jb
Z + Rear Seat
http://uprev.com/dealers.php
Check 'em out...
-jb
