Shop Builds Temp moving posts for some clean up of this section.
Twin Turbo VQ35HR *Performance Factory Exclusive* 465whp @8.3psi base tune
Old May 7, 2008 | 03:34 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Default Twin Turbo VQ35HR *Performance Factory Exclusive* 495whp @ 10.5psi
*NEXT DAY EDIT* Well the first day on the dyno we fully tuned the car with the haltech, we did all the part throttle stuff, all the idle, and all the low boost all the way up to high boost. the car was very very hot cause we did it all in about 6 hours time. now, this morning we decided to do a pull or two on a nice cool engine, we also safely upped the boost to 10.5 psi. the car makes 10.5 and then falls a bit probably due to the 2.5 inch test pipes...
Here are the results!!! i LOVE this car !!!
The tires on this car are really really off balance, on my dyno when that happens, well it causes a really shakey graph
Nice little Haltech screenshot for you.
we played with the tach signal and switched the wires around and got it to pick up a little better, its still pretty shakey like yesterday. parts skip out a little on there, but you get the idea
well guys, back in february we started to do a twin turbo kit for an HR. the owner of this car is a 16 year old guy named mike, out of south florida. he looked around and decided Performance Factory was the place to get this setup done. it took us about two weeks to fully fabricate the whole thing to perfection. we modified the HKS GTRS kit to fit and made a lot of changes. we utilized the greddy intercooler package and then add a few more things to make it all run.
it took us about two months after the fab work to get everything wired up and working perfectly, plus working on the completely new and different crank and cam timing codes takes a bit of time too.
Big thanks to Hal at Injected Performance on helping us figure out some "top secret" stuff...
Here are the dyno graphs, we could not get a solid tach signal so we dont have torque or vs. rpm. we tried and tried. the boost levels are on the graph. the most we did was 8.3 because we wanted to keep this car in one piece for a while. this is VERY very conservative due to the fact that there arent many HR TTs. We should be building a second engine that mike, the owner, has here shortly so we can continue to push the envelope. we WILL push this setup a lot farther, we just want to get him his car back so he can drive it for a while...
This build consists of..
Haltech Platinum HR version
HKS Twin Turbo GTRS kit
Greddy intercooler package
Performance Factorys HR twin turbo upgrade package
JWT HR clutch and flywheel
HKS EVC6 boost controller
Greddy Ti-C True Dual exhaust
Deatschwerks 600cc injectors
Walbro fuel pump
Tial 50mm blow off valve
Im sure there are a few more odds and ends we included on there as well.
Pictures of car... we will get some whole shots of the car when we get it down and cleaned up. still need to polish up the intake pipes or have them coated. not sure which one would look better...
Old May 7, 2008 | 03:36 PM
bboypuertoroc's Avatar
bboypuertoroc
Great job.
How hard do you think the stock HR block can be pushed?
Old May 7, 2008 | 03:39 PM
blasian's Avatar
blasian
That's awesome dude.
Old May 7, 2008 | 03:41 PM
Audible Mayhem
My350z
500 whp dynojet for sure with no problem. i really just want to get mike his car back because it took a little longer than we thought. we will push it more one day soon though..
Shabib67's Avatar
Shabib67
That is awesome!!! When are you giong to start offering this package and do we have to ship our car to your facility or will you out right sell the package and can this be done with an F-Con?
Old May 7, 2008 | 03:48 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
I foresee PF being swamped for the rest of the year now. Guys better reserve their spots on the calendar now. Great job guys.
Old May 7, 2008 | 03:54 PM
10 TIL 4's Avatar
10 TIL 4
+1 What he said! Also......verrrrrry niiiiiice...hoooow much?
Old May 7, 2008 | 03:58 PM
bboypuertoroc
That's what I like to hear.
ToastZ's Avatar
ToastZ
Nice.
Old May 7, 2008 | 04:00 PM
XKR's Avatar
XKR
Very nice..... BTW Jeremy....why do you think it will take 500whp ? Is it because of the rods....or is there something else ?
Old May 7, 2008 | 04:02 PM
failsafe306's Avatar
failsafe306
Does the throttle body piping being Y'd like that not cause one side to get more air than the other? You'd think that a majority of the pressurized air would go into the drivers side TB.
Old May 7, 2008 | 04:05 PM
MrKaira's Avatar
MrKaira
Really MrZ31
that is AWESOME!!!!! I can't wait to see the long term results of this kit!
Old May 7, 2008 | 04:06 PM
Audible Mayhem
My350z
We are offering the same exact package for around 12 000 right now. this comes with everything you will need , installed and fully tuned.
Haltech platinum
HKS GTRS turbo kit
All piping and filters
Deatschwerks injectors
Walbro fuel pump
This is pretty much the same price that it costs to do a similar setup on your VQ35DE...
i could tell while tuning it that it had more in it. watching all the pretty colors and things moving around on the Haltech made me think that...
Old May 7, 2008 | 04:07 PM
Audible Mayhem
My350z
well the plenum is completely open inside so that shouldnt be an issue...
Old May 7, 2008 | 04:11 PM
10 TIL 4's Avatar
10 TIL 4
Any vids of the dyno?
Old May 7, 2008 | 04:12 PM
warmmilk's Avatar
warmmilk
does the stock strut bar fit?
Old May 7, 2008 | 04:13 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Greatness.
blasian's Avatar
blasian
Most important question of all.
Old May 7, 2008 | 04:15 PM
Audible Mayhem
My350z
Great question, and yes, it will, with about 2 inches of clearance...
Old May 7, 2008 | 04:24 PM
Nexx's Avatar
Nexx
HR's are sick. 460whp at 8psi.
i know the rods in HR are much beefer, so that kinda relieves that concern, what else might be a concern when it comes to longevity when pushing that much power on a stock block?
