Jim Wolf Tech. Clutch/Flywheel Combo 775 w/ Free Parts w/ 3Day Shipping! IN STOCK!!
Old Apr 16, 2009 | 01:54 PM
Mike@CZP's Avatar
Mike@CZP
Concept Z Performance
Default Jim Wolf Tech. Clutch/Flywheel Combo 775 w/ Free Parts w/ 3Day Shipping! IN STOCK!!
Hey Guys
I have this absolutely unbelievable deal going on these Jim Wolf Clutch and Flywheels. This combo is the most popular drive train combo available in today's market, and with this affordable price there should be no reason not to pick one up. THESE ARE ALWAYS IN STOCK AND SHIP THE SAME DAY!!!!
Here is what I am offering to the My350z Community:
Brand new Jim wolf Clutch and Flywheel Combo : $775.00 SHIPPED
Brand New Concept Z Stainless Clutch Line w/ Kit : FREE
Brand New JWT Throw Out Bearing : FREE
Brand New Jim Wolf Technology Adjustment tool : FREE
Brand New CZP Upgraded Chromoly Clutch Pivot Ball : FREE
Brand New Nismo Pilot Needle Bushing : Free!
Only we include the Alignment Tool in our combo.
TO order, click the add-to-cart button to be taken to the site and checkout through our secured web-store:
Jim Wolf Technology Clutch and Flywheel Combo Member Special
This is the best clutch/flywheel combo available for the 350Z/G35. With 1200KG clamping force, the need for a harsh, non-organic friction material is eliminated. This clutch makes a solid connection even with our nitrous spool-up kit to 570+HP. JWT Flywheels are made using the highest quality and most modern materials available. A noticeable, quicker acceleration will be experienced. JWT flywheels are 13lbs in weight, compared to the heavy 23lb stock flywheel. Includes the throw-out bearing, pilot needle, and adjustment tool.
The stock Nissan pivot ball is made from a weak Grade 5 steel and from 10+ years of use have a tendency to break when an upgraded clutch is installed. We have made our Pivot ball from Chromoly to withstand the extra force of an upgraded clutch. This is a must have part for anyone upgrading to a performance clutch!!!
The Stainless Steel Clutch Line is a must have upgrade for the 350Z/G35 with an upgraded clutch. This will eliminate the mushy pedal feel, that ALL Z's have after installing high clamping force clutches. The kit works wonders with Dual Disc clutches as well. By eliminating all soft points in your hydraulic system, it adds to pedal response, feel, and gives you a little more adjustability in the pedal height!
The original pilot bushing is just a metal sleeve that the transmission input shaft slides into. These sleeves usually get worn out, and leave shavings inside the bell housing. The Nismo Needle Bearing rotates with the transmission input shaft, and won't cause any wear on either the bearing or shaft.
We also Recommend:
Jim Wolf Technology Heavy Duty Clutch, $420.00 Shipped
Description:The JWT 350Z Heavy Duty Street Clutch is now available. The JWT Clutches are still the #1 Nissan vehicle clutch upgrade available. With 1200KG clamping force, the need for a harsh, non-organic friction material is eliminated. This clutch makes a solid connection even with our nitrous spool-up kit to 570+HP. The JWT Street Clutch is still the most streetable clutches on the market.
JWT 350Z Aluminum Flywheel 03-06, $415.00 Shipped
Description: JWT Flywheels are made using the highest quality and most modern materials available. A noticeable, quicker acceleration will be experienced. JWT flywheels are 13lbs in weight, compared to the heavy 23lb stock flywheel. These flywheels will work with the stock 350Z Clutch(850KG) and the 300ZX Twin Turbo Clutch (1150KG), for larger HP applications.
JWT Replacment Flywheel Friction Plate Insert
Redline MT-85 (4-Pack) - 350Z, $57.20 Shipped
Description: Recommended for Nissan 350Z, 370Z, G35, and G37 (also most Maxima, Altima & Sentra).
* Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
* Offers quicker shifts, perfect synchronizer coefficient of friction * Eliminates notchy shifting, even when cold
* High performance gear protection and longer synchro life
* Recommended for GL-1, GL-3 and GL-4 applications, as well as where most special synchromesh fluids are specified
* Satisfies the gear oil viscosity requirements of 75W, 80W, 85W and motor oil viscosities of SAE 30 and 5W30.
Includes 4 Quarts to complete the Job
Nissan OEM 350Z Rear Main Seal, $30.06 Shipped
Description: It's a good idea to replace the rear main seal when you replace your clutch. These tend to leak if you use Synthetic oil on a high mileage vehicle.
Need more clamping power? We recommend Southbend Clutches for higher HP outputs:
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - Rally Series (433 TQ Cap). $750 Shipped
____________________________________________________________
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - TZ Series (475 TQ Cap). $800 Shipped
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 3 (525 TQ Cap). $850 Shipped [IMG]https:/conceptzperformance.com/images/cart2.gif[/IMG]
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 4 SS (600 TQ Cap). $900 Shipped
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - FE Stage 5 SS (690 TQ Cap). $950 Shipped
Old Apr 23, 2009 | 09:52 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Apr 30, 2009 | 09:27 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Apr 30, 2009 | 02:11 PM
klaze1's Avatar
klaze1
does this clutch combo work on the 07+
Old Apr 30, 2009 | 02:28 PM
Mike@CZP's Avatar
Mike@CZP
No, you are looking for this combo:
https://my350z.com/forum/drivetrain/...0-shipped.html
Old May 7, 2009 | 09:23 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old May 13, 2009 | 08:52 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old May 15, 2009 | 09:49 PM
07_z33's Avatar
07_z33
so which clutch & flywheel do i get for $775? looking for a clutch & flywheel for my z. thinking either stage 2 or 3.
Old May 20, 2009 | 08:18 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old May 22, 2009 | 09:07 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old May 28, 2009 | 07:47 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 3, 2009 | 08:13 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 11, 2009 | 08:50 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 15, 2009 | 02:32 PM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 17, 2009 | 12:06 PM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 19, 2009 | 08:54 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 23, 2009 | 10:50 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 24, 2009 | 02:29 PM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 29, 2009 | 11:52 AM
Mike@CZP's Avatar
Mike@CZP
bump
Old Jun 30, 2009 | 10:23 AM
Mike@CZP's Avatar
Mike@CZP
bump
