Accessing rear adjustable coilovers?
Old 04-22-2017, 01:21 PM
PintofBrew
PintofBrew's Avatar
Default Accessing rear adjustable coilovers?
Hi guys,
I've recently had MCA blue fully adjustable coil-overs installed and its easy enough to adjust the fronts (simply pop the hood and turn the **** to desired stiffness) but I can't access the struts at the rear for the life of me!
I've removed pretty much all my pretty plastic bits in the boot but it looks like unless I put a hole in the body I have no easy access... I know my garage adjusted the rears initially stiff as f$*# and said to me to adjust fronts only cause its a pain in the **** to get to the rear coilovers, but its too stiff... Any help greatly appreciated!
Attached Thumbnails Accessing rear adjustable coilovers?-20170423_065243.jpg
Old 04-22-2017, 03:40 PM
dcains
dcains's Avatar
You can cut a pair of holes , or just remove them, soften the stetting, and reinstall. Only two nuts at the top, and a nut/bolt on the bottom.
Old 04-22-2017, 08:55 PM
PintofBrew
PintofBrew's Avatar
Cheers mate
Old 04-22-2017, 08:56 PM
Big unibit and drill a hole.i cut mine up about 3/4 inch
Old 04-22-2017, 08:57 PM
PintofBrew
PintofBrew's Avatar
Drilling a hole did you notice any change to refinement? Cars noisy as is lol
Old 04-22-2017, 09:07 PM
My car has full solid bushings, high springs rates, gutted interiour and the exhaust is explicit loud
Old 04-22-2017, 09:32 PM
dcains
dcains's Avatar
You definitely don't want to keep the hole open on a street car. Paint the edges with rustproofing primer and find a rubber plug to fit.
