Spacer question
Old 04-25-2019, 07:18 PM
Snidd
Snidd's Avatar
Default Spacer question
I have done some research and measuring, I got a 03 350z, just got Z1 Akebono BBK, (Rears clear no issues with 25mm spacer). my front wheels are 18x8.5+35 (SuperAdvans(they have about 12mm for lug bolts to tuck into if needed)) tires on front 255/40-18, car is lowered about 1inch(fender is just above top of tire tread), Im pretty sure all i need is about 10-15mm spacer to clear the BBK, my question is, if i got 20mm spacers for the front would that come close to any rubbing issues on turns?
Old 04-25-2019, 08:04 PM
mr. sparco
mr. sparco's Avatar
What size tires? Rubbing wouldn't be an issue unless you have some crazy fat tires in the front. With 15mm spacers you would be at +20 which is still very conservative since 8.5 is fairly narrow.
I have 19x10 +15 Advan RSDs on 275/30 tires in the front, no rubbing issues at all.
Old 04-26-2019, 09:27 AM
Snidd
Snidd's Avatar
perfect,thank-you very much(front tires are 255/40-18)
celt
09-02-2008 09:48 AM
plumpzz
10-21-2005 08:00 PM
boma
05-16-2005 07:32 AM
etang789
03-14-2005 02:38 AM
apharmdb
06-25-2003 12:03 AM
Quick Reply: Spacer question
