Got a full vband turbonetics kit. Had to piece it together and got a vs racing turbo and having issues spooling it. Only build like 2-3 psi. I did boost leak test and fixed the little leaks but problem still persists. Turbo is 67/62.
It is a problem. you might have enough washers or spring rate in there to hold most of the boost, but it should be leaking
the proper way is to have a vac line which holds it down under booster and opens it quicker under vac/boost from throttle plate closing not only making it easier on the turbo from surging but making sure it does not leak under boost
I've attached a pic i found online for reference. red line is what you need
car hits 7psi and rips. Don’t need to plumb the bov as I’m a step away from putting plate instead. To each their own on surging. Car is doing great.
