Map Switching/ Cruise Control/ UPREV
Old Jun 6, 2026 | 10:09 PM
Bandicoot_Z33's Avatar
Bandicoot_Z33
Default Map Switching/ Cruise Control/ UPREV
I have a 6 speed base model 2008 350z (HRMT) and have added the CC (cruise control) switches along with the clutch cancel switch and brake switch to go with it. I know since it is a base model the cruise cluster light wont turn on. I got tuned with UPREV but cant switch maps or use launch control unfortunately. My tuner has made sure to use a rom from a z that has it from factory.
Things i have tried:
changing clock spring
removing and reseating the clutch and brake switch
Things i think might be affecting it:
I have a CEL (check engine light) from Camshaft Position Sensor "a" bank 2
ABS light is on. Codes for abs below
c1111 (pump motor)
c1104 (left front sensor 1)
c1140 (actuator rly)
Brake light is on and doesnt throw code up
Any help is much appreciated thanks!
Old Jun 11, 2026 | 06:46 AM
GreyZ's Avatar
GreyZ
Any ABS lights will prevent cruise from functioning in my experience. I am unsure how it affects map switching.
Bandicoot_Z33
Jun 6, 2026 09:47 PM
tom991
Mar 18, 2025 08:39 AM
Bmsluite
Oct 3, 2024 04:30 AM
Shane86
Tuning
May 24, 2015 10:38 AM
mgrotel
Tuning
16
Feb 15, 2012 10:14 AM
