Best place to get an alignment in NC, SC
Might sound like a stupid question. But with previous cars (and the current Z) I have been to many alignment shops and none of them seem to get it down right.. I guess you can say im tad picky on this part but I would like to know if anyone knows of a good palce to get an alignment around Raleigh/Fayetteville area.. ALSO possibly Spartanburg, SC area (since ill be moving there withing next 5 months..)
Thanks
Thanks
Kevin at MM Autowerks does great work. You can even hang out with him in the shop and watch all the magic happen. he is a little more expensive than other places, but i can promise you he is well worth it.
http://www.mmautowerks.com/
He is located in Morrisville, NC (Basically Raleigh, near the airport).
Hope that helps.
Sean
Hope that helps.
Sean
This is good info... The dealership has damaged my wheels now 3 times doing either an alignment(covered under warranty), wheel balance or tire install. I guess I should have learned after the forst or even the second time.
350Z_Al
Oct 29, 2020 07:44 PM
