Help Check Engine Light On!
Old Feb 25, 2007 | 01:57 PM
FullmetaledZ's Avatar
FullmetaledZ
Default Help Check Engine Light On!
HELP guys i just install my arc induction box n suction pipe n the check engine light is on...does anyone know wuts wrong with it n how to fix the problem? let me know guys PLZ!
Old Feb 25, 2007 | 01:59 PM
farobaba's Avatar
farobaba
happens, specially if u unplugged the MAF sensor and turned the key on.. all u need to do is take it to autozone and have them reset the light, make sure u get the code, the PXXXX code.
hope this helps
Old Feb 25, 2007 | 02:02 PM
team1320350z's Avatar
team1320350z
disconect your battery, then stick the key in ignition and turn it to on position for 10 seconds then remove it, plug battery back on and start it up. it should work then go smoke an evo.
Old Feb 25, 2007 | 02:44 PM
FullmetaledZ
anything else i tried team1320350z already n it didnt work..havnt gone to autozone yet...i will tomorrow
Old Feb 25, 2007 | 02:45 PM
farobaba's Avatar
farobaba
yea that battery disconnecting thing won't work on the Zs. Since they use a memory capacitor. I strongly suggest using an OBDII scan tool, rather then messing around with the battery and fuses
Old Feb 25, 2007 | 02:46 PM
FullmetaledZ
so go to autozone den rite? n do u guys know if they can do that today since its sunday?
Old Feb 25, 2007 | 02:50 PM
farobaba's Avatar
farobaba
yea they r open on sundays till 7pm i believe, and it only takes like a few mins! Make sure u get the print out from them, if available
Old Feb 25, 2007 | 02:52 PM
FullmetaledZ
THANZ so ur sure this will work? or the best way?
Old Feb 25, 2007 | 02:54 PM
farobaba's Avatar
farobaba
im very sure it's gonna work, when i installed my Nismo V2 CAI, i had the same problem, then when it got replaced with the JWT pop charger, same problem, and both times i disconnected the MAF.
Old Feb 25, 2007 | 02:59 PM
FullmetaledZ
i just called them..n they said that they dont do it,they give me the scanner n explain to me how to do it...how would i get the print out? n do i need to know my code first?
Old Feb 25, 2007 | 04:01 PM
FullmetaledZ
hey guys i just went to to autozone n scaned it n got my codes but they told me that the scanner wouldnt get rid of the engien check light wut do i do?plz help!
Old Feb 25, 2007 | 04:22 PM
FullmetaledZ
help ppl!
Old Feb 25, 2007 | 04:23 PM
farobaba's Avatar
farobaba
how is that even possible. if it can read it can erase too. What was the light on for? what did it say?
Old Feb 25, 2007 | 05:12 PM
gimpster621's Avatar
gimpster621
reset the ecu
http://www.technosquareinc.com/350reset.htm
whats the deal with the wheels?
Old Feb 26, 2007 | 11:30 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
dude... what was the code?? that's the most important part!
Old Feb 26, 2007 | 06:18 PM
team1320350z
same thing has happened to me twice and i always disconect the battery, then stick the key in ignition and turn it to on position leave it like that for 10 seconds then remove it, plug battery back on and start it up always works for me, just make sure you wait 10 sec.
Old Feb 27, 2007 | 08:18 AM
farobaba's Avatar
farobaba
depends on the code type too.. under powertrain, is it a hard/memory code or a soft code.
Old Feb 27, 2007 | 01:38 PM
FullmetaledZ
I have the codes and have tried other methods but no luck anymore or just go to the dealership n let them do it
Old Feb 27, 2007 | 01:41 PM
TheCajunStyle's Avatar
TheCajunStyle
holy s h i t.............. WHAT DID THE CODE SAY???????????????
