Helllp!!! Flat Front Tire
Old Apr 12, 2003 | 07:07 PM
Tenn_SZ's Avatar
Tenn_SZ
Default Helllp!!! Flat Front Tire
My left front tire just went out. It looks like the wall was puctured. It is pretty much done. Does anyone know where I can get a tire ASAP??
Tenn_SZ
Old Apr 13, 2003 | 01:49 PM
dczoner's Avatar
dczoner
Any luck? Have u tried the dealer? What sort of prices are you looking at for the fronts? Also, what gave you the flat?
Take care, good luck.
Old Apr 13, 2003 | 02:31 PM
Tenn_SZ's Avatar
Tenn_SZ
Default fixed
I originally thought that the inside wall was punctured. But after taking the tire off I found the hole on the tread. Unfortunately I don't know what caused it. So, I had it fixed at the local Firestone/Bridgestone dealer.
I did check around for the tire. pretty much all the major places I called had to order the tire. None had the tire in stock. I found that on Tire.com (Tire Rack) they had the same stock tire for $180 and I saw tire that ranged from 150 (Nitto V ratte) to 200+ (Michelin).
Thanks for the concren.
Tenn_SZ
Old Apr 13, 2003 | 02:39 PM
Z yA L8eR's Avatar
Z yA L8eR
dude that stinks...good luck man..drive safely and have fun
Old Apr 13, 2003 | 08:00 PM
frenzee's Avatar
frenzee
Just curious if anyone has tried putting on run flats like Dunlop, or Firestone. I believe Michellin and Bridgestone and others make run flats too, but I'm not sure if they would fit a wheel that wasn't specifically designed for that tire. Common sense would say, all else being the equal, a run flat must weigh more. On the other hand, driving even for a short distance on flats could ruin the rims.
Old Apr 15, 2003 | 08:43 PM
fisherprice's Avatar
fisherprice
Yeah a guy I work with has a run flat on his front.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
