HELP:Titek Cf Air Duct Stencil Needed
Old Apr 20, 2007 | 10:18 AM
lb's vq35's Avatar
lb's vq35
ya i really appreciate it james or tech if any of you guys can help me out..... keep me informed...
Old Apr 20, 2007 | 02:02 PM
james840a's Avatar
james840a
Here you go, i just got mine just now. Here is the Instructions and Templet
Old Apr 20, 2007 | 04:19 PM
lb's vq35's Avatar
lb's vq35
GREAT THANK U !!!!
Old Apr 21, 2007 | 08:13 AM
james840a's Avatar
james840a
Your Welcome, when you get installed, take some pictures.
Old Apr 21, 2007 | 09:14 AM
lb's vq35's Avatar
lb's vq35
sure man i think im ganna do it on sunday got some zignals too for my bday that i want to install sunday....
Old Apr 21, 2007 | 07:03 PM
james840a's Avatar
james840a
i got mine installed today, havent taken pictures yet. Just a heads up. On the templet align Section-A and Section-B. At the bottom of Section-B line theres a curve, that doesnt match up with the headlight. And plus the opening will need to be bigger then the templet, just on 2 sides. When cutting opening do not cut sharp points at the corners do to the mounting holes.
Please see the Attached picture for the info I described above witch is in red.
All i used to cut the hole was a Dremel Tool with a cut off wheel and a drum sanding bit, witch comes standard with Dremel Tools. Also be sure to use Masking Tape on the area that you are going to work before starting job. It will make life easier.
Oh also use some alum. washer on the back side for more mounting striegth if you use the rivits.
Attached Thumbnails HELP:Titek Cf Air Duct Stencil Needed-airduct1.jpg
Old Apr 21, 2007 | 09:02 PM
lb's vq35's Avatar
lb's vq35
wow thnks man you been very helpful
Old Apr 22, 2007 | 10:03 AM
ecorona6's Avatar
ecorona6
With so many stencils, did you install it yet? Pictures are a must after all this assistance!
Old Apr 22, 2007 | 10:27 AM
lb's vq35's Avatar
lb's vq35
i havnt but hopefully i do today
Old Apr 22, 2007 | 11:12 AM
james840a's Avatar
james840a
Theres only one stencil here. Here are some of my pictures
Old Apr 22, 2007 | 11:23 AM
Eazzy's Avatar
Eazzy
Numbers are the only thing in life that never Lie. If you relaxe and get over you'alls panic attacks, you will do fine. No one should be without a Dremal and the ability to use it. Refer to the contour of you're Duct and the contour of you're Bumper, take measurements.
If youre uncomfortable with the honesty of Numbers, make the hole smaller and carefully increase till you have a perfect fit.
Personally, if I got a templete,--for anything, I wouldnt trust it until I made my own measurements and even then I would make it smaller and increase as the need requires
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
