EDFC question?
Old Jul 28, 2008 | 07:05 AM
El Guy's Avatar
El Guy
Default EDFC question?
I have the Tein Flex system with EDFC. I just wanted to know once I have my adjustment set, Should i turn off the head unit or is it ok to have it on all the time. The reason I asked this is my second head unit. The first one went out on me and the head unit just read error. So i was thinking if it was just safer to adjust and just turn off the system. I will just turn it on when its needed.
Old Jul 28, 2008 | 08:31 AM
steve5's Avatar
steve5
you don't need to turn it off. it doesn't use enough juice to drain your battery.
Old Jul 28, 2008 | 08:54 AM
El Guy's Avatar
El Guy
Its not about the battery use. i had a previous one and it just went out and it just started to read error codes never worked. So i just dont want this one to go out also. So i was thinking if its safer just to adjust and turn on when i need it.
Old Jul 28, 2008 | 09:21 AM
THE ROADSTER's Avatar
THE ROADSTER
I leave my EDFC on all the time, if you turn it off you have to re set it every time.
Old Jul 28, 2008 | 10:31 AM
El Guy's Avatar
El Guy
I just don't want the head unit to go out again. So was thinking to adjust and turn off to try to avoid any problems. I really dont change it that much, So i would not mind to turn of and reset when needed.
The roadster do you know how to adjust the heights on the coilovers?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
