cosworth plenum question
Old Dec 30, 2008 | 07:55 AM
Boneout JZA80's Avatar
Boneout JZA80
Shine Auto Project
Question cosworth plenum question
I think this piece is pure hotness, anyone know the numbers it puts down for NA as well as FI?
thanks
Old Dec 30, 2008 | 08:00 AM
turismo's Avatar
turismo
thanks
I have a polished one brand new in the classifieds.
Force induction has seen an increase of 30-40hp in the upper rpms. Not sure of n/a though
Old Dec 30, 2008 | 08:02 AM
Boneout JZA80
Shine Auto Project
thanks for the reply
wow thats hella power
Old Dec 30, 2008 | 08:10 AM
turismo's Avatar
turismo
no problemo
Old Dec 30, 2008 | 10:26 AM
THE TECH's Avatar
THE TECH
NA won't show much more if any over the plenum spacers out there now. More bling unless you have big power coming down the road.
Old Jan 11, 2009 | 06:46 AM
13SECZ's Avatar
13SECZ
You say it won't show much power...
Will it however hold the characteristics of the REV up better then the Motordyne stuff...
What I mean is that I get great midrange power with the spacer and lower plenum ....will it keep that but then give me what I lose next to redline right now....?
My power drops off or flattens a bit from 6k and on....where in stock form it didnt...my peak HP was around 6800 stock....
Thanks,
Old Feb 11, 2009 | 09:09 PM
SergEK's Avatar
SergEK
Thanks,
It gained 12whp untuned on a stock REVUP motor....I think with tuning youll see a little more and it should carry power as far as the cams can support it...which will follow the trace of the stock power but just carry it a little longer.
First and foremost the sources I spoke to inside Cosworth knew that it would require an increased rev limit and tuning to extract the most gains from it because its so different from the stock mani.
When I first learned this back in 07 I was a little sad because at the time tuning wasnt cheap and HKS VPRO was needed (unless you wanted the UTEC hiccups)
Now REVUP guys should start with tuning and work there way forward IMO....OSIRIS is a must even on a stock Z....the stock REVUP tune is very conservative and there are gains to be had even stock...not to mention the fuel savings.
I think OSIRIS, straight pipes, dual 2.75 exhaust are a great bang for your buck...figure 6-700 for a tuned OSIRIS, 250-300 for the straight pipes and 550-600 for the duals...
Either way an extra 500rpm and the proper fuel with the cosworth mani would go a long way for stuff you can slap on a Vq motor without much hassle and extract good gains...people have spent much more than the 999-1100 that this mani costs and havent gained 12whp in some cases....If you can even just hold the power to redline from 6000 rpm to 7500rpm you can see the sizable gains you can make
My car ran super rich (into the 11's) the last time I hit the rollers and I have been dying to test the car as is with just a leaner/more aggressive map with the small mods I have...
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
