Question for those with KW Coilovers
Old Jan 27, 2010 | 10:31 AM
halfrice's Avatar
halfrice
Default Question for those with KW Coilovers
Currently running JIC-FLTA2's but rear is set to the highest and its too low. Need the car to clear 3.5" under for the event im building the car for. Always loved KW coils and considering going with the V2's since I can only use 2 way adjustable coilovers (ride height and dampening). How do you guys feel about the ride height? is it too low, too high, or does it have enough adjustment to ride close to stock and slammed? Appreciate the info, thanks guys.
Old Jan 27, 2010 | 12:47 PM
Scott@fontananissan's Avatar
Scott@fontananissan
Vendor - Former Vendor
We are KW dealers...and I've personally raced on KW's for the last 4 years. These things perform!!!
The KW's will allow you to run from Stock height to slammed depending on your needs. Shoot me a pm with what you need and I'd be happy to help you out!
Scott
Old Jan 27, 2010 | 12:49 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
None of the KW will let you go to stock rideheight, and none will slam it (short of the clubsports)
For all the KW V1-V3 units, rideheight specs are the same - Height adjustment from .8 inches lower than stock to around 1.5 inches lower than stock.
