Headlight Restoration
Old Apr 1, 2010 | 03:22 AM
SDUrbn350Z's Avatar
SDUrbn350Z
Default Headlight Restoration
ok so my headlights are yellowing pretty bad since my Z stays outside -_- you can notice the yellowing and the oxidation on the outer part of the plastic im planning on getting Meguiars PlastX and maybe wet sanding it down first, i know this has been posted before but i did my search and no body ever posted the steps they did so any help would be greatly appreciated like what type of grit sand paper and how long did it take. i need to do this asap so someone help me!!!
Old Apr 1, 2010 | 10:15 AM
fairladyboss's Avatar
fairladyboss
https://my350z.com/forum/repairing-a...storation.html
Old Apr 1, 2010 | 10:46 AM
Anomaly's Avatar
Anomaly
Start with the gentlest method first!
The PlastX is pretty good at clearning headlight haze. My method is to use a sponge (like a wax applicator sponge) and work in the PlastX until it disappears and buff off the excess PlastX with a MF towel. If it doesn’t clear the haze initially, repeat.
If the PlastX works, then I’ll use a quick detail spray to clean/wipe the headlights and then apply a sealant (ie, Opti-Seal) to protect the lights.
Give the PlastX a try first and then look into how to wet-sand your headlights.
Old Apr 1, 2010 | 10:49 AM
oscatipo's Avatar
oscatipo
rotary buffer with a yellow cutting pad and swirl remover
Old Apr 1, 2010 | 10:55 AM
threetothefour's Avatar
threetothefour
damn after black housing my headlights, water goes into headlight right now... cant be good. i gotta reseal them...
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
