LS Engine Swap
Old Jun 27, 2011 | 09:50 AM
RKnight's Avatar
RKnight
Default LS Engine Swap
Has anyone done or know of a LS engine swap in CA and the difficulty and requirements for getting a smog test?
Old Jun 27, 2011 | 10:16 AM
JDMStanced's Avatar
JDMStanced
you'll prolly get tickets for having LS in CA lol if you ever get it done, i want to check it out in person
Old Jun 27, 2011 | 11:36 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Isn't the law with engine swaps the engine year code must be newer then the year the car made?
Found this link maybe it will help: http://www.importtuner.com/newsstand...nes/index.html
Old Jun 27, 2011 | 01:46 PM
BEBO'S ZEE's Avatar
BEBO'S ZEE
^same year or newer engine and you can't swap an SUV/truck engine in a car. Than you would have to go to a smog reff to get it legalized(so all smog stuff must be hooked up)
Old Jun 27, 2011 | 02:08 PM
JDMStanced's Avatar
JDMStanced
i thought onnly engines from same factory can be legally swapped, no? like you can't put a chevrolet engine in nissan
Old Jun 27, 2011 | 02:16 PM
skitso1080's Avatar
skitso1080
http://www.arb.ca.gov/homepage.htm
Do your research here to find out. It will help you stay legit.
Old Jun 27, 2011 | 03:08 PM
Rx Punk's Avatar
Rx Punk
If it makes our car fast, its illegal. Moderate improvement is all that's allowed in CA.
Old Jun 28, 2011 | 01:55 PM
RKnight's Avatar
RKnight
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Talked to someone at CARB and they directed me to this page on their site.
Look under heading for Engine Changes
Old Jun 28, 2011 | 02:02 PM
RKnight's Avatar
RKnight
Once the swap is complete you have to take the car to a referee and they sign off on these requirements. After that you just get smog checks as usual without having to go back to a referee.
Old Jul 11, 2011 | 08:51 PM
johnwigs's Avatar
johnwigs
GM performance E-ROD kit will work... problem is the exhaust manifolds are nowhere near fitting which have the cats on them... so then "legal" catalytic converters are needed on top of the kit
$6500 inc LS6 engine (SS camaro), harness, control unit, and smog canister,
+trans
+ sikky LS oil pan, mounts, and headers w/ exhaust
+ three way catalytic converters... high flow cats will not pass referee inspection
+ alot of custom fabrication to get guages and everything associated working correctly
Old Jul 12, 2011 | 12:06 AM
caaraa's Avatar
caaraa
Old Jul 12, 2011 | 07:32 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
Vehicles converted to 100% electric drive, with all power supplied by on-board batteries are considered in compliance with the engine change requirements. All fuel system components must be removed prior to inspection. For additional information contact the ARB helpline at (800) 242-4450
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine
Old Jul 15, 2011 | 07:40 PM
johnwigs's Avatar
johnwigs
http://www.race-mart.com/GM_Performa...-19256487.html
E-rod is 50 state compliant
originaly designed for california legal hot rods, legal in any car as long as ALL emission equipment is used
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 27, 2015 09:23 AM
