Need a professional interior cleaner
Old Jun 9, 2013 | 08:20 PM
m0nkie's Avatar
m0nkie
Default Need a professional interior cleaner
I need a professional detailer to help me clean out a milk stain on the carpet. Half gallon of milk exploded in the heat and got soaked into the carpet. I tried to clean it as best as I could.. but still can somewhat smell that odor.
any recommendations? I live in Walnut, 91789. Anywhere in SGV, LA, or even OC.. need a prof. shop that has vacuums to wash it out..
thanks
Old Jun 9, 2013 | 08:23 PM
Bmurray350z's Avatar
Bmurray350z
milk stain huh?
Old Jun 9, 2013 | 08:35 PM
Chebosto's Avatar
Chebosto
bissel upholstery cleaner might work for you.. with a wet vac
then woolite...
thats if you want to DIY.
Old Jun 9, 2013 | 09:35 PM
m0nkie's Avatar
m0nkie
milk stain huh?
if it's that you are speaking of, I wouldn't be half as pissed right now.. but it is milk.. and an entire half gallon of it
Old Jun 9, 2013 | 09:36 PM
m0nkie's Avatar
m0nkie
then woolite...
thanks.. I'll keep trying.
Old Jun 10, 2013 | 03:20 PM
Chebosto's Avatar
Chebosto
this one
Amazon.com: BISSELL Spot Clean Pro Portable Deep Cleaner, 3624: Home & Kitchen Amazon.com: BISSELL Spot Clean Pro Portable Deep Cleaner, 3624: Home & Kitchen
Old Jun 10, 2013 | 03:56 PM
IDrm350's Avatar
IDrm350
That much milk got UNDER the carpet. You won't get the smell out without cleaning everything including the foam and insulation under the carpet. The only way to clean it effectively is to remove the carpet. It's more work up front but will be totally worth it.
I've done this. Remove the seat, remove the center console, and other trim pieces that cover/hold the edges of the carpet (kick panel, door sill trim, etc). The two halves (driver and passenger) of the carpet are only connected with two small strips that go over the transmission tunnel. Cut them so so you can remove only the dirty side.
Now you can wash however you so please. I used Dawn dish detergent in the bath tub to get out cat **** (don't ask). I was able to fully submerge it in scalding hot water and leave it out to completely dry. No hint to the original smell or mustiness from damp carpet/insulation. Carpet was better than new also, you'd be surprised how dirty the carpet is even if it looks clean. The water in the tub was nasty brown! :vomit:
When you put the carpet back in, reattach the two strips you cut somehow. I just tapped them. The console covers the whole area so you don't see it. It's probably not even necessary to worry about it.
Old Jun 10, 2013 | 07:09 PM
Neeko94's Avatar
Neeko94
Why not rake the matts to a dry cleaner?
Probably not more than $6 a piece
but for everything else.......
Old Jun 10, 2013 | 10:39 PM
m0nkie's Avatar
m0nkie
the matts are out already.. dumped almost a bottle of vinegar to cover the smell and sprayed some baking soda just now. tomorrow I'm taking it to a professional to do a steam vac.. then I'll use the spray Cheston recommended and wipe it for a week or two..
fingers crossed.. hope I don't have to tear out the carpet
Old Jun 12, 2013 | 11:27 AM
m0nkie's Avatar
m0nkie
so a little update.. the vinegar and baking soda really helped..
There's a local car wash that ordered some special cleaning powder and wet vac'd my carpet.. I left the windows open the whole night. Today, the smell is 85% gone.. now it smells like a hint of milk with a hint of sour (vinegar) and some hints of mint.. car wash wanted me to go back Friday for a 2nd job to remove the rest of odor..
in the mean while, i've been spraying pet stain removals and Glad carpet powder with baking soda over night.. then vacuuming it in the morning. Hope it works out.. if not, time to cut some carpet out
Old Jun 17, 2013 | 05:03 PM
IDrm350's Avatar
IDrm350
Good luck! Hope it works.
Between the effort and money you already spent and that last little bit of nagging odor (mixed with the new smells you introduced), you could have just done what I suggested!
Old Jun 17, 2013 | 05:10 PM
350zchad's Avatar
350zchad
odor bomb will do it.. but to actually fix the prob.. carpet must be removed and everything cleaned and any pad replaced
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
