Tire Size Recommendations??
Old Jan 26, 2004 | 01:44 PM
rogerudc's Avatar
rogerudc
Question Tire Size Recommendations??
I recently purchased my Volk Te37s (19x8.5 Front & 19.9.5 Rear).
While set on front tire sizes, I've been looking at various tire sizes for the rears and I'm still undecided.
285/30/19
285/35/19
295/35/19
275/30/19
Anyone have any opinions/recommendations on any of these sizes? There is a Mustang Cobra parked outside my office building with 285/35's and they look pretty good.
Old Jan 26, 2004 | 02:29 PM
iris's Avatar
iris
I have 19" Volk GT-7's, front 19x8.5", +23mm offset, rear 19x9.5", + 24mm offset.
I went with front: 245/35/19 and 275/35/19. Not one of the sizes you listed, but there it is.
If you're set on your front sizes, I'm not sure why you want to run a different sidewall on your rears. ??
Old Jan 26, 2004 | 02:33 PM
LaoSiFu's Avatar
LaoSiFu
Default Re: Tire Size Recommendations??
285/30/19
285/35/19
295/35/19
275/30/19
Must got one hell of a deal on your Volk Roger
Old Jan 26, 2004 | 02:43 PM
rogerudc's Avatar
rogerudc
lol LaoSiFu
Old Jan 26, 2004 | 04:53 PM
lowrider's Avatar
lowrider
As iris said, the proper size for the car and the wheels you chose is 245/35/19 and 275/35/19 front to back. The sidewall height and outside diameter is correct, and the car will handle noticably better then with stock sizes.
Lou
Old Jan 26, 2004 | 07:09 PM
2003z's Avatar
2003z
285/35-19 is just as close to spec as 275/35
http://www.miata.net/garage/tirecalc.html
Old Jan 27, 2004 | 08:14 AM
rogerudc's Avatar
rogerudc
GREAT CALCULATOR 2003Z. tHANKS
Old Jan 27, 2004 | 08:17 AM
rogerudc's Avatar
rogerudc
Iris,
This is where I read about the idea. Let me know what they say when you ask them why they vary front/rear tire height in their wheel & tire packages.
http://www.stillen.com/sportscars_pr...nd=&subcat=320
Old Jan 27, 2004 | 10:01 AM
lowrider's Avatar
lowrider
Go here and you'll see 245/35/19 and 275/35/19 Toyos as the recommended choice.
http://www.stillen.com/sportscars_pr...r=&TrimFilter=
Lou
Old Jan 27, 2004 | 10:48 AM
Scott Webb's Avatar
Scott Webb
I'm running the following:
Front - 19x8.5 +22 offset w/ 245/35-19
Rear - 19x10.5 +35 offset w/ 275/30-19
These sizes were specified by Volk for this car.
Love the way it drives and looks. Can't wait to get it on the track.
Old Jan 27, 2004 | 12:39 PM
rogerudc's Avatar
rogerudc
Very nice Scott. That Z link of yours gave me some great ideas too.
Old Feb 4, 2004 | 12:10 PM
sgt_bo's Avatar
sgt_bo
Was wondering if 235/40/18 front Toyo T1S would mess the ride up.
Also how about 245/45/18 Rear. Or what size should I get for the rear. The dealer has already purchased the front ones for me. Need help quick..
Thanks
Old Feb 4, 2004 | 12:18 PM
rogerudc's Avatar
rogerudc
sounds good to me. However I have noticed that typically the tire height on the rears is equal to or less than the fronts on most high performance exotics (Guess they want to keep the back end as closeto the ground as possible. Maybe go with 245/40/18's or 245/35/18's in back.
Old Feb 4, 2004 | 12:28 PM
zland's Avatar
zland
Sport Z Magazine
1. 35 series is the percent of the tire width thus a 35 series tire that is a 245 wide is a smaller wall ht than a 35 series tire in a 275 width for example. The outside diameter is what is important ie ABS, VCD etc...
2. The wider the tire, more wt but better grip. If you look at Road and Track where the motorX 350Z had my tire sizes 295/265, it pulled a .94 laterial G vs .91 on the 275/245 combo on other Z's. the article itself points out the added grip of the wider tire as the reason. I would ask yourself if you are going to mod the motor such as FI. If so, bigger tire with added hp would be a good combo. If you keep the motor stock and want an extra 1-2 hp feel in the butt dyno measurement, the 275/245 combo might be a better choice.
3. Not everything is based on logic. A sports car is not logical compared to other cars that carry more people etc. What do you like, you mentioned 285's? If you like it, that is all that matters. Remember, 17" wheels are better performing tires, if you dont believe it, check out what guys that track their Z's are using. The fact is many guys put 19" wheels on their Z for looks thus if you like the look of a 285 vs 275, the it is the same thing but in this case, you will get more grip. Good luck!
Jeff - zland
Old Feb 4, 2004 | 12:54 PM
rogerudc's Avatar
rogerudc
great feedback. I knew larger diameter wheels/tires slowed the car down, but always questioned why exotics come equipped with them (just based soley on looks? (i.e. the new 2005 Mercedes SLR Mclaren comes with 255/35/19's up front and 295/30/19s in back, because 17's would like kinda stupid on a $450,000 car??)
Old Feb 5, 2004 | 04:46 AM
sgt_bo's Avatar
sgt_bo
Talking Tire Sizes Questions still
Ok, I have gotte the 235/40/18 Toyo T1-S for the front tires. (dealer purchased)
Now what should I get for the rear to make the car look good, and the ride not suffer.
options
275/35/18
245/45/18
275/40/18
Any help would be helpful.
Old Feb 5, 2004 | 01:22 PM
Scott Webb's Avatar
Scott Webb
Big brakes are another reason for large diameter wheels. Most racing cars will use the smallest diameter wheel possible that fits over the largest brakes they're allowed. I know of at least one series, however, that mandated larger wheels to emulate street trends.
Old Feb 5, 2004 | 05:41 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Scott...and a couple other people have it right. The aspect ratio is just that....a ratio of height to width. So a 245/35 will be shorter than a 275/35. The reason I know this is becuase i have the 245/35 and 275/35 setup, and the rear tires is materially taller than the front. Next time, I will get a 275/30 for the rear.
Old Feb 5, 2004 | 05:59 PM
lowrider's Avatar
lowrider
Mr. gq_model
Stick with what you have. If you get a 30 series rear, your front and rear Outer Daimeters will be same, and you'll kill the stagger. I'm assuming you don't have VDC, but you do have slip. Eather of them would not like the fronts and rears being the same, and will let you know it by flashing the light. Also, the car is built for proper handling with the stagger, it shouldn't be messed with.
Lou
Old Feb 5, 2004 | 07:33 PM
ranger5oh's Avatar
ranger5oh
Also... as far as running small diameter wheels. Top speed gets sacrificed with small wheels. You always have an accelleration/top speed tradeoff. This is why some exotics may also choose larger wheels.
