Smog test
Old Mar 12, 2004 | 08:58 AM
Grey Matter's Avatar
Grey Matter
Default Smog test
I am thinking of getting LBMS test pipes or hi/flow/cats and was wonder if anyone knows how often we will have to have the Z smogged (I have a 03). Also how hard would it be to swap out test pipes for stock cats when the time came?
Thanks
Old Mar 12, 2004 | 09:12 AM
yobri's Avatar
yobri
4 years after the purchase of a new car and then every 2 years afterwards.... or so I've heard.
Old Mar 14, 2004 | 09:14 PM
SHO-TIME's Avatar
SHO-TIME
I doubt the smoggers look underneath the car to see if you are missing cats... do they? If you pass the visual inspection and assuming that the "test pipes" that you get have sensor connectors for the OBII, there shouldn't be a problem passing smog. Z's are pretty clean buring cars. If not, pls let me know! B/C I am considering going straight too... pure straight. *lol*
ps.. I forget how much the penalty is if they catch you running straight pipes. $1000?
Old Mar 14, 2004 | 09:29 PM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
can't pass smog at all if you go with test pipes. Also but you rarely see it is those portable smog stations that the cops put up and randomly test your car. Just like those DUI checkpoints during new years. If you fail and see that you don't have the cats on worse case scenario is a $3800 fine. Like I said you rarely see the cops do the random testing and I've only seen it twice up in santa clarita.
Old Mar 15, 2004 | 05:20 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Your car won't pass the sniffer with test pipes. Swapping the cats is an hour start to finish (at least with a lift). My car with RT Cat's, cams, ECU.....etc, passes the sniffer just fine. We've run mine on the smog machine half a dozen times now doing various tests.
Old Mar 15, 2004 | 06:43 PM
SHO-TIME's Avatar
SHO-TIME
$3,800 fine!? hmm... I guess straight pipes are out for me then.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
