Springs anyone?!?!?! SWIFT SPRINGS IN-STOCK!!!
Old Jul 2, 2010 | 01:19 PM
KamiSpeed's Avatar
KamiSpeed
Vendor - Former Vendor
Arrow Springs anyone?!?!?! SWIFT SPRINGS IN-STOCK!!!
Performance like no other, SWIFT springs provide the best springs out there hands down. One of the few suspension companies whose main product are Springs.
If you are lookings for performance without replacing shocks/struts then look no further.
Sports Springs ($399 MSRP) - In Stock
Spring Rate: 6 kg/mm front / 6.5 kg/mm rear
Drop Rate: .8 inch front / .6 inch rear
Swift made Sport Springs keeps your quality ride you get from showroom, and adds a sporty feel and lower ride height for sport driving enthusiasts and style minded drivers who demand only the best.
Swift did not start developing Sport Springs by trying to drop the ride height. Unlike others who only care about style, Swift approached to create lowering springs with 3 rules.
1 Keep or improve a smooth comfortable ride.
2 Increase handling, control, and performance.
3 Lower the vehicle within the each vehicle’s usable stroke.
Most end users understand and had experiences with the typical harsh and uncomfortable ride from lowering springs. Performance on lowering springs is often overlooked by manufactures because most lowering springs are design to cater appearance oriented customers. The results are usually bumpy corning that cause a decrease in traction, or excessive worn shocks cause by lowering the vehicle beyond the usable stroke. The problems with most lowering springs are quite simple. First is due to the lowering amount, and second, the coiling design of the spring.
So what is the difference between Swift and other manufactures?
I always thought that springs are just springs?
We utilize a less coil design to create a much more responsive spring. With fewer coils, we can completely eliminate the chances of coil binding and increase the amount of usable stroke. Also, fewer coils on lowering springs will create a faster reaction speed towards any road conditions. So instead of skipping on the harsh road surface, the spring will reacted to the road surface as needed.
SPEC-R ($419 MSRP) - In Stock
Spring Rate: 5.2-7.5 kg/mm front / 5-8.2 kg/mm rear (changes upon conditions and equipment on the car)
Drop Rate: 1.2 inch front / 1 inch rear
Specification & Data Sheet: PDF File
Sport Springs SPEC-R
For motorsports minded individual with a passion in winning.
Swift made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1 Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
PM me for prices and shipping cost!!!
If you are looking for Coil Springs contact me and I can price you those as well
Old Jul 2, 2010 | 01:39 PM
Adon's Avatar
Adon
you left out the two most important pieces of information people want to know when buying springs
- spring rates
- drop
so can you post those
Old Jul 2, 2010 | 02:18 PM
KamiSpeed's Avatar
KamiSpeed
- spring rates
- drop
Thanks, idk what I was on to forget that... but they're up
Old Jul 3, 2010 | 10:55 AM
KamiSpeed's Avatar
KamiSpeed
bump
Old Jul 6, 2010 | 12:52 PM
KamiSpeed's Avatar
KamiSpeed
bump bump
Old Jul 12, 2010 | 12:12 PM
KamiSpeed's Avatar
KamiSpeed
bump
Old Jul 14, 2010 | 07:17 AM
KamiSpeed's Avatar
KamiSpeed
bump for swift!!!
Old Jul 16, 2010 | 12:42 PM
KamiSpeed's Avatar
KamiSpeed
in stock!!!
Old Jul 26, 2010 | 10:27 AM
KamiSpeed's Avatar
KamiSpeed
bump
Old Jul 29, 2010 | 11:18 AM
KamiSpeed's Avatar
KamiSpeed
bump
Old Aug 4, 2010 | 12:29 PM
KamiSpeed's Avatar
KamiSpeed
bump!!
Old Aug 20, 2010 | 02:18 PM
KamiSpeed's Avatar
KamiSpeed
BUMP!
Old Aug 24, 2010 | 03:49 PM
KamiSpeed's Avatar
KamiSpeed
bump!
Old Aug 26, 2010 | 02:23 PM
KamiSpeed's Avatar
KamiSpeed
tttttt
Old Aug 27, 2010 | 11:23 AM
KamiSpeed's Avatar
KamiSpeed
tttttt
Old Sep 1, 2010 | 10:51 AM
KamiSpeed's Avatar
KamiSpeed
bumppp
Old Sep 3, 2010 | 02:15 PM
KamiSpeed's Avatar
KamiSpeed
bumppppppppp
Old Sep 7, 2010 | 01:21 PM
KamiSpeed's Avatar
KamiSpeed
bump
Old Sep 8, 2010 | 02:00 PM
KamiSpeed's Avatar
KamiSpeed
BUMP!
Old Sep 8, 2010 | 02:56 PM
2g4u's Avatar
2g4u
pm'd
