FS: Eibach/SPC front A-Arms (Z/G)
Old May 9, 2011 | 09:18 PM
217350z's Avatar
217350z
Smile Eibach/SPC front A-Arms (Z/G)
I have a used set of Front A-Arms, camber arms etc. These were on my 350z for around 5k miles. I have replaced both new ball joints.
These retail for $350+ (true value)
i just want $280obo
From SPC:
These front upper control arms will give you -1 degree to +1.0 degree caster change and up to -2.5 degrees to +2.5 degrees camber change. Simply replace the OE front upper control arms and dial in your suspension angles with our patented sliding ball joint and caster plate. Whether you want to tune your suspension for the ultimate in handling performance, minimize tire wear or easily move back and forth between the two settings, these are the arms to get the job done.
Front Adjustment range: Camber: -2.5 degrees to +2.5 degrees
Caster: -1.0 degrees to +1.0 degrees
http://www.flickr.com/photos/62660355@N08/5706201004/http://www.flickr.com/photos/62660355@N08/5706201004/ by http://www.flickr.com/people/62660355@N08/, on Flickr
http://www.flickr.com/photos/62660355@N08/5706187962/http://www.flickr.com/photos/62660355@N08/5706187962/ by http://www.flickr.com/people/62660355@N08/, on Flickr
http://www.flickr.com/photos/62660355@N08/5706184898/http://www.flickr.com/photos/62660355@N08/5706184898/ by http://www.flickr.com/people/62660355@N08/, on Flickr
http://www.flickr.com/photos/62660355@N08/5706190866/http://www.flickr.com/photos/62660355@N08/5706190866/ by http://www.flickr.com/people/62660355@N08/, on Flickr
http://www.flickr.com/photos/62660355@N08/5705629855/http://www.flickr.com/photos/62660355@N08/5705629855/ by http://www.flickr.com/people/62660355@N08/, on Flickr
http://www.flickr.com/photos/62660355@N08/5705632793/http://www.flickr.com/photos/62660355@N08/5705632793/ by http://www.flickr.com/people/62660355@N08/, on Flickr
Old May 9, 2011 | 09:59 PM
TurboTom's Avatar
TurboTom
pm sent
Old May 11, 2011 | 02:17 PM
217350z's Avatar
217350z
SOLD to turbo tom .
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
