Momentum Performance Upper Arms Stance Toe Camber Arms
Old May 11, 2011 | 02:35 PM
thmotorsports's Avatar
thmotorsports
Vendor - Former Vendor
Smile Momentum Performance Upper Arms Stance Toe Camber Arms
SUPER INTRO PRICING COMBO DEALS!!!
For those who need more performance form their 350Z suspension we have some pretty cool parts to showcase!
Momentum Performance Upper Control Arms For 350Z - in stock!
The Momentum Performance Nissan 350Z Upper Control Arms offer a wide range of performance benefits for both track and daily driving.
Momentum Performance 350Z Control Arms make use of one-piece billet 7075 aluminum construction, which reduces the weight of these suspension components compared to the stock units while at the same time adding rigidity, strength and response – three important factors for drivers looking to “Push Forward” with their vehicle’s performance. Aurora spherical rod ends also improve the durability of the control arms by removing rubber bushings from the equation.
An additional advantage offered by the Momentum Performance 350Z Control Arms is the four-degree range of camber adjustability that helps track drivers dial in more precise suspension and alignment setups while also allowing street drivers to adjust for lowered ride heights in order to maintain maximum grip and reduce tire wear.
Fitment for 2003-2009 350Z
FEATURES
CNC machined, aircraft grade 7075 aluminum
Black anodized design for aesthetics and durability
Aurora rod ends with Grade 8 locking hardware
CNC machined mounting spacers and ball joint adapters
ADVANTAGES
Allows use of factory frame mounts and hardware
+/- 4 Degrees Camber Adjustment
Branded with Momentum Performance logo
From the company that brought to you some of the most toughest and high performance suspension systems, STANCE is bringing more control to the table with their new Aurora spherical rod end equipped suspension links.
STANCE - Nissan Z33 Rear Toe Rods
Adjustable toe rods in the rear allow the driver to tune the chassis to any individual's driving characteristics, style, and experience. The amount of Toe-in and -out will allow the rear tires to respond according to each driver's needs. STANCE Rear Toe Rods are a must for any serious driver looking to maximize control over their toe specs.
Note: You must have "true" coilover type to use this link. This link replaces the OEM lower arm that has the spring housing.
Nissan Z33 Rear Camber Arms (RCA)
Rear Camber Arms are an ideal suspension modification after lowering any Z33. The RCA will allow for proper rear camber adjustment and aid in maximizing handling and braking abilities while saving tires from uneven tread wear. In addition the arms will also keep the camber true during hard/competition drifting or racing.
The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. The Stance links use Aurora's strongest billet 3 piece rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability. Our rod ends offer a high misalignment angle for extreme performance.
PM US OR CALL US FOR BEST PRICES AVAILABLE AND FOR ANY DESIRED COMBO DEALS!!!
Looking forward in hearing from you.
Thank you,
Adam
THMotorsports
800-959-0145
www.thmotorsports.com
adamk@thmotorsports.com
AIM = adamkthm
Old May 12, 2011 | 07:56 AM
Jun's Avatar
Jun
Need a quote for the front control arms shipped to 33156 please.
Thanks in advance.
Old May 12, 2011 | 08:29 AM
ocdz's Avatar
ocdz
a arms to 43065 business.
thanks
Old May 12, 2011 | 12:15 PM
thmotorsports
Thanks in advance.
thanks
PMs sent!
take advantage of the special intro pricing!!!
Old May 16, 2011 | 08:38 AM
ATL_Red_G35's Avatar
ATL_Red_G35
PM me the toe arms please.
Shipped to 30043
Old May 16, 2011 | 12:21 PM
thmotorsports
Shipped to 30043
PMd ya!!
Old May 16, 2011 | 12:34 PM
Hpnotiq_Drifter's Avatar
Hpnotiq_Drifter
uca shipped to 33063
Old May 23, 2011 | 03:38 PM
thmotorsports
PMd ya!!!
Old May 23, 2011 | 03:46 PM
FATPUBUS's Avatar
FATPUBUS
Nice! Front arms to 77373
Old May 23, 2011 | 04:02 PM
thmotorsports
Old May 24, 2011 | 03:12 PM
thmotorsports
Thank you for all the orders and all the support!!!
Adam@THM
Old May 24, 2011 | 06:22 PM
thepitt02's Avatar
thepitt02
front upper control arms shipped to 23692, thanks.
Old May 25, 2011 | 09:45 AM
thmotorsports
PMd ya
Old May 26, 2011 | 10:41 AM
thmotorsports
Checkout our Facebook for updates on our race car!
THMRacing STi Facebook
Old May 27, 2011 | 12:23 PM
thmotorsports
For those who race!
Old May 30, 2011 | 01:39 PM
dorkstar's Avatar
dorkstar
Need a quote for the front control arms shipped to 90712
Thanks
Old May 31, 2011 | 09:44 AM
thmotorsports
Thanks
PMd ya
Old Jun 2, 2011 | 08:50 AM
thmotorsports
Thank you for the orders!!!
keep em coming guys!!! sick intro price
Old Jun 3, 2011 | 01:22 PM
thmotorsports
Happy Friday Everyone!!!
-Adam@THM
Old Jun 4, 2011 | 12:10 AM
Flippz350's Avatar
Flippz350
price for front control arms shipped to 94080. thanks
