FS: Megan RS Coilovers g35/350z
Selling My Megan RS Coilovers
Local pick up only
Located In Corona CA
Price 1300
only 300 miles on them
Features:
SPRING RATES:
F: 62mm ID; 200mm length; 12kg/mm
R: 62mm ID; 210mm length; 10kg/mm
DAMPER SPECS:
F: 125mm stroke; 220mm length
R: 125mm stroke; 220mm length
- Pillow Ball Upper Mounts
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Dual-Cylinder Design
- Steel front brackets/ Steel rear brackets
NOTE: Damper extension ***** are included for the rear coil-overs.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
Local pick up only
Price 1300
Features:
SPRING RATES:
DAMPER SPECS:
- Rubber Dust Boots
