FS: Demo Set of Ohlins Road and Track Coilovers.
Reason for selling: I'm looking to switch to a true rear coilover system so that I can fully utilize my Roberuta Cup Kit.
I have a set of very gently used (under 1000 miles) set of Ohlins Road and Track coilovers for sale to suit the 2003-2008 350Z and 2003-2007 G35 coupe and sedan (non AWD model only). These were used for demonstration purposes only and are in as-new condition. Shown unassembled out of the box in the picture, but you will receive them fully assembled upon delivery.
These feature Ohlins DFV valving, pillowball mounts front and rear, 2 way height adjustment. These allow for over a 2 inch drop, yet maintain the OEM rear suspension layout. Out of every coilover we have used on these cars (over 20 combos to date), these are, without question, the most composed, balanced set. The valving adjustments are meaningful….a click makes a difference that can immediately be felt.
Specs:
•Spring Rates: Front: 572 lb/in, Rear: 315-400 lb/in (very slightly progressive)
•High quality lightweight aluminium construction
•Gas pressurised with Nitrogen to reduce oil cavitation
•Single adjustable with 40+ clicks of rebound adjustment
•Internal gas reservoir
•Threaded spring platforms on damper body for independent spring preload adjustment
•Independent ride height adjustment via threaded lower mount
•Fitted with camber adjustable pillowball top mounts (where applicable)
•Fitted with dust covers to protect dampers from road dirt and to prolong service life
•Corrosion salt spray tested to ISO 9227
•2 year manufacturer warranty
•All dampers are dyno tested and matched before delivery to the customer
•Dampers can be revalved to suit specific customer requirements
Ive seen these sell these new for $3359+$65 shipping in the 48 states. I'm offering this set for $2695 delivered in the 48 states. Local pickup from Long Island or Queens, NY is also available. Worldwide shipping available for an additional cost. This is a private sale.
Specs:
