Clutch is sticky??and low end weak?
Old Jul 22, 2007 | 10:59 PM
cowboyth's Avatar
cowboyth
Default Clutch is sticky??and low end weak?
first off my clutch sometimes will go about half way down and then just stay there until i use my foot to bring it back up. My buddies said it could be a slate piston? Any Suggestions?
Also i took the Z out to Ennis and was runnin horrible times, it seems like my my car lags at the low end but my top end feels normal. All i got on it is an exhaust y-pipe, popcharger, and plenum spacer.
I was thinking a tune would help, will nissan do anything since the car is still under warranty?
Old Jul 22, 2007 | 11:04 PM
IbarraZ33's Avatar
IbarraZ33
yiiikesss... you have a slight burned clutch!!! i had this to... and everytime id put it to gear and give it gas it would lag!!! Take it to the stealership and tell them whats happening...
Old Jul 22, 2007 | 11:09 PM
cowboyth's Avatar
cowboyth
thanks, do you know if this kinda thing will be covered under warranty by nissan?
Old Jul 23, 2007 | 04:24 AM
bommart's Avatar
bommart
probably not. unless they find a defect, a clutch is like tires or brakes...wont be cover'd under warranty just because it is worn out.
Old Jul 23, 2007 | 05:53 AM
theaxe1149's Avatar
theaxe1149
sounds like the clutch slave cylinder. my friend had the same problem in his Z28. pedal would stay half way to floor untill he lifted it with his foot. cost him $200 to get it fixed.
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
