TPMS question
Old May 1, 2008 | 05:52 PM
1z2envy's Avatar
1z2envy
Default TPMS question
Doh! I meant to put TPMS as the subject.....well anyway,
If I put 350z wheels on my car and it caused the TPMS sensor to go off, how do I get it to stop?
The tires and rims have never been seperated, they were literally removed from a stock 350z and put on my car. Now the TPMS sensor is going off.
I already tried disconnecting the negative wire from the battery and it did nothing.
Just wondering if I'm stuck with this little light going off, even though the wheels I have on are on another nissan vehicle.
Mind you the sensors are still on the Z wheels and were never removed, wheels are untouched. Sensors still on.
Any ideas?
Old May 2, 2008 | 10:17 AM
MrWatchDawg's Avatar
MrWatchDawg
is the 350z not yours?
the TPMS is mounted in the wheels, thats how it checks the air pressure.
and if you got the tpms from another z and put htem on yours, you have to go get them re programmed from the stealership.
Old May 2, 2008 | 10:34 AM
Gclipsed's Avatar
Gclipsed
yup the ones on your original wheels are programed to your car....if you still have them discount tire will remove them and reinstall them on your new wheels
Old May 2, 2008 | 11:00 AM
timsam's Avatar
timsam
Just like the guys said above...a set of TPMS is programmed for a specific car.
So if your new rims and tires have TPMS in them, you can go to Discount Tire and have them re-programmed to your car. If they dont have TPMS, then i would think Discount could turn it off, or at the very least the stealership could.
Good Luck! That light and beep are annoying!
Old May 2, 2008 | 03:40 PM
NISMOFO's Avatar
NISMOFO
When you remove a sensor from the wheel though, it needs to be rebuilt (or resealed). So Discount Tire will also charge you $5 per valvestem/sensor as well. So you're looking at $20 extra every time you remove sensors from one wheel and put them in another.
Also, I think I read that the batteries in the sensors are supposed to last up to 10 years....I think.
Definitely go to a dealership to get the reprogrammed. Also, it's easy to spot a Z that has these sensors just by looking at the valvestems.
Old May 3, 2008 | 10:51 PM
tquill's Avatar
tquill
I have a question related to this thread. Would the TPMS work on an 03 base? A version that never came with the TPMS to begin with? I'm guessing it could be lacking some programming or something to that effect?
Old May 4, 2008 | 03:40 PM
NISMOFO's Avatar
NISMOFO
No it wouldn't.
Old May 4, 2008 | 07:37 PM
JRinTXrog's Avatar
JRinTXrog
Discount Tire just told me I had to take my car to the dealership to get mine programed. I had one busted and had to get a new one.
Old May 5, 2008 | 06:32 AM
firedancer's Avatar
firedancer
Does anyone know about how much the stealership charges for reprogramming the sensors to your car (all 4)? I'm looking at buying some new stock rims with TPMS included and was just curious how much it would cost me every time I switch rims on my Z. Thanks!!
Old May 5, 2008 | 06:34 AM
blasian's Avatar
blasian
My buddy works at the dealer, I believe he told me they charge $50.
Old May 5, 2008 | 07:20 AM
firedancer's Avatar
firedancer
Thanks for the info...not as bad as I figured it would be.
Old May 6, 2008 | 06:26 PM
1z2envy's Avatar
1z2envy
cool, then I will go see if I can get them reprogramed at discount first....then try the dealership....if that doesn't work...I appreciate the assistance guys...thanks!
Old May 6, 2008 | 06:34 PM
NISMOFO's Avatar
NISMOFO
Don't waste your time going to DT to get them reprogrammed. They don't do that kind of thing. This is a nissan part with a nissan program. Discount just knows how to mount the valve stem/sensors to the wheels and that's it.
Just go to your dealership.
Old May 6, 2008 | 11:03 PM
MrWatchDawg
ya dealership is the only place you can get them programmed from anyway!
trust me ont hat
and every dealership is different bro!
Old May 7, 2008 | 06:46 AM
blasian's Avatar
blasian
Correct... they use the Consult-II to program them.
Old May 8, 2008 | 10:11 AM
shiftdrift06's Avatar
shiftdrift06
Anyone know how much it cost for a sensor? I think one mines got busted when I got some used tires.
Old May 8, 2008 | 11:13 AM
NISMOFO's Avatar
NISMOFO
Brand new they're like $250 a piece. A used set here on the forums goes for around $100 shipped....give or take a few bucks. Look in the wheel/tire section.
Old May 8, 2008 | 12:06 PM
z-u-later's Avatar
z-u-later
+1 on only the dealership being able to re-program your TPMS.
As a clarification, TPS refers to the sensors that are installed on your rims. TPMS is the part that recognizes the TPS and displays your tire pressure on your dash.
If possible, you really need to label the TPS before they are re-programmed (or even after) to ensure that they are always installed on the same location -- LF, RF, LR, RF. Once programmed, the TPS will need to be installed at the same location in order for the TPMS to recognize them. It should cost less than $100 for the TPMS to be re-programmed.
Old May 10, 2008 | 01:50 PM
zstreet86's Avatar
zstreet86
yeah i went to discount today cuz i put 06 wheels (w/ tpms) on my 03 and they told me to go to stealership
Old May 10, 2008 | 05:19 PM
LegionnaireZ's Avatar
LegionnaireZ
ehh... f-it... i'm not getting banned for nothing
issyz
Jul 2, 2017 03:04 PM
