the *new* my350 Marketplace Buy, sell and post your wanted items in here, for free.
Brake Cooling Deflectors 350Z/G35
For Sale
Brakes
  • Brakes - Brake Cooling Deflectors 350Z/G35 - New - 2003 to 2008 Any Make All Models - Chicago, IL 60618, United States
    Expired
    Expired
    Expired
    Expired
    Expired
5 Year Member
  • Price
    $175
  • Location Chicago, IL, 60618, USA
  • Condition New
  • Compatibility
Make Model Year
Any Make Any Model 2003 - 2008
Description:
I make and sell these brake cooling deflectors. They are a Porsche OEM part modified to cool the brakes of the 350Z/G35 chassis. This Drastically cools down the front brakes on this chassis. Full benefits if you remove the dust shield.
If you track your car this is a no brainer mod. They bolt directing the front lower control arm. Takes about ten minutes a side.
I cannot provide 100% accurate cooling data as it varies widely due to application. For my 07 350Z with the brembos it has dropped peak rotor temperatures on track by well over 200F. I tested this with rotor temperature paint. The paint will not give me exact numbers obviously. This is a drastic drop in temperature for a track session.
If you are running a crazy angle kit this will not work. If you are running a 12" wheel will some kind of crazy odd high offset this probably won't work either.
$175, paypal good and services with free shipping
There is also an eBay listing if you feel more comfortable buying it there. You'll have to pay shipping.
I put way too much work and time coming up with this design and tweaking it work properly to respond to troll posts.
​​​​I will respond to actual questions. Feel free to PM me as well.
Old Dec 18, 2022 | 01:07 PM
Escobar's Avatar
Escobar
pm sent, ill take a pair
Old Dec 18, 2022 | 01:38 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
I responded. Check your inbox
Old Dec 20, 2022 | 04:59 AM
RobPhoboS's Avatar
RobPhoboS
International shipping possible? (At buyers cost of course)
Old Dec 20, 2022 | 05:20 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
Yes, I will ship it overseas if you want to pay the shipping cost. I am in Chicago if you would like to look up rates from different shipping outfits and see what is the most economical. Package usually weighs 1.5 pounds and the dimensions of the boxes I put them in are around 8"x10"x6"
Old Dec 20, 2022 | 05:29 AM
RobPhoboS's Avatar
RobPhoboS
Fantastic, I shall check out some options and PM you.
Looks like a nice option to have, I wanted to make something myself but at this point, other commitments etc etc
Old Dec 20, 2022 | 05:36 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
Oh yeah I get it. It took me a long time to design and tweak these to optimise flow so it would work. All in between everything else I've got going on. Just a little bit at a time. Such is life.
Old Dec 20, 2022 | 07:13 PM
flavalava's Avatar
flavalava
5 Year Member
Will this still be beneficial if dust shield isn’t removed?
Old Dec 21, 2022 | 05:17 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
Yes, you do not need to remove the dust shield for this to work. The dust shield is shaped to allow air to enter into the rotor cooling inlet on the bottom front side of the rotor. This is exactly where the deflectors send the air. The inlet is circled in the picture below.
Old Dec 21, 2022 | 11:54 AM
The Bull's Avatar
The Bull
I wonder how these would compare to the tubes?
Also how ride height would affect airflow as well. In track racing they use the tubes since at their height one of the main effects is to prevent air to be trapped in this area so a hose solves this but adds complexity and faster deterioration when compared to your deflectors.
I think I saw this on the 3D group on FB. Good ****!
Old Dec 21, 2022 | 02:03 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
A lot of teams are actually switched from the hose/duct setup to this deflector type. All that dictates flow is differential of pressure. The higher the pressure at the inlet and the lower the pressure at the outlet. How you get that pressure high does not matter.
The issue with hoses and ducts is that each 90 degree bend in a 3 inch hose effectively adds 10 feet to the hose. Each 30 degree bend adds about 6. A 120 degree bend adds nearly 20 feet of hose to the effective pressure drop. Some setup have a theoretical length of 35 or more feet! I know all this because I am a maintenance mechanic at a printing press shop. Lots of drying ink. Lots of hoses. I've learned a lot..
There is no pressure drop with a deflector. It just hit the deflectors, diverts, and whatever it hits suddenly has super high pressure.
In this case it is hitting the rotor cooling vane inlet. High pressure at the inlet. Low pressure on the outlet. Wallah! Brake cooling. It's worlds more effective than I imagine it would be. I believe that inlet is in a low pressure zone. This changes it to high pressure. I do not have another explanation for why these are so effective.
Old Dec 21, 2022 | 05:37 PM
Escobar's Avatar
Escobar
cool, looking forward to running these
Old Dec 22, 2022 | 05:14 PM
Kwame's Avatar
Kwame
I’ll take a pair. Whats your PayPal address?
Old Dec 22, 2022 | 05:39 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
PMed you
Old Dec 29, 2022 | 04:27 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
I tried sending you a message with your tracking number. It says you have too many messages stored so I can't send you anything. Delete some and I will send you your tracking #
Also, You will notice there is a stiffening tab on your brackets that is not in the pictures. I stiffened up the design just to prevent any form of metal fatigue that may or may not have occured over time. I like my parts to last and I am sure you do too.
Old Jan 11, 2023 | 02:53 PM
bar1ow's Avatar
bar1ow
I would also like a pair if you still have any
Old Jan 11, 2023 | 03:29 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
PMed
Old Jan 16, 2023 | 05:55 AM
isy_nismo's Avatar
isy_nismo
Very interesting option..... wonder if it will work with my nismo ducts fitted?
Old Jan 16, 2023 | 05:58 AM
isy_nismo's Avatar
isy_nismo
Did you have the nismo brake ducts installed? are you planning to install this as a conjunction, I have the nismo ducts like yours but I'm considering to add this deflectors as well, pls help!!
Old Jan 31, 2023 | 02:55 PM
atoz33's Avatar
atoz33
Running 18x9.5 +15 in the front and full lock they do rub the deflectors a bit, nothing some trimming can't fix though. Excited to see how these perform!
