unichip piggyback ecu
Old May 10, 2005 | 07:22 PM
jkoc's Avatar
jkoc
Default unichip piggyback ecu
http://www.unichip.us/unichip_home.asp
has anyone looked into this thing? does this work?
Old May 10, 2005 | 07:27 PM
g356gear's Avatar
g356gear
It should work.....that's what APS uses as their TT/ST kit piggy back.
Old May 10, 2005 | 07:29 PM
jkoc's Avatar
jkoc
seems like a good deal economically too -- unlimited
retuning -- send it back anytime you get new mods.
also, i like the fact that in theory, you can still temporarily drive your car when you've shipped the piggyback unit to unichip... albeit not optimal performance.
Old May 10, 2005 | 08:05 PM
g356gear's Avatar
g356gear
Full plug and play
Old May 10, 2005 | 10:24 PM
vegasedge's Avatar
vegasedge
The place there site tells me to buy it from www.performanceproducts.com tells me this."You are buying for a
2003 NISSAN 350Z changeTo BUY this product:
Unichip is not available for 2003 NISSAN 350Z"
Hmm...
Old May 11, 2005 | 12:31 AM
King56's Avatar
King56
There is a listing for this under the vendor classified section right now, https://my350z.com/forum/showthread.php?t=120768
Has anyone tried one of these out yet?
Old May 11, 2005 | 04:42 AM
nearly zer0's Avatar
nearly zer0
not sure about the Z, but unichip tuning on subarus was just about useless.. for the same functions i'd go with an e-manage..
Old May 11, 2005 | 05:24 AM
DomZ's Avatar
DomZ
Look at the gains they posted though...I'm extremely curious now.
Old May 11, 2005 | 05:30 AM
jkoc's Avatar
jkoc
not sure if you can compare like a subaru to nissan car... kind of an apples to oranges comparison heh
Old May 11, 2005 | 06:36 AM
Zivman's Avatar
Zivman
In terms of gains this will be NO different than a ECU flash. There is only so much tuning that can be done to a N/A car. Fuel map and timing map. You either do this via a piggy back or through flashing the ecu.
Old May 11, 2005 | 06:48 AM
roneski's Avatar
roneski
http://g35driver.com/forums/showthre...hlight=unichip
Old May 11, 2005 | 06:49 AM
DomZ's Avatar
DomZ
Yes, but a reflash requires REMOVING your ECU and sending it out thus being without your car for a while. This chip is PnP, can be put in and taken out at the drop of a dime....and the HP/$ ratio is better, $15 for a new flash?!?! I may be ordering one of these next week.....
Old May 11, 2005 | 06:59 AM
DomZ's Avatar
DomZ
Wow...
Old May 11, 2005 | 07:11 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is a great discussion. I actually spoke to a representative from Unichip and gather more information on exactly how the Unichip does what it does.
Turns out that the Unchip enriches fuel via MAF adjustment, rather than physically driving the injectors (similar to the Split Second Box/R4 software/SAFC). So in terms of functionality, the eManage is actually a better solution, since it includes drivers for both the injectors and the coils. So instead of tricking the MAF sensor, you can add IPW directly with the eManage.
Becuase there are limitations with MAF correction based enrichment, it will be interesting to see if the APS folks can get precise timing and fueling at very high boost levels.
Unichip's main purpose with their products, is to provide pre-loaded maps that enhance power and trq on OEM cars. For F/I cars, you might want to consider a different solution.
Old May 11, 2005 | 07:14 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I was just gonna post the same thing. I've been doing some research and came across that and just made up my mind. Technosquare flash for me.
Old May 11, 2005 | 08:37 AM
Billyz 212's Avatar
Billyz 212
what if you want o stay n/a is it worth it then and will it work on an 03'
Old May 11, 2005 | 09:36 AM
jkoc's Avatar
jkoc
woah
Old May 11, 2005 | 05:48 PM
KPierson's Avatar
KPierson
You definately should check in to local tuners also. I'm going to be getting a Unichip with my APS TT and I have to drive over five hours to get it tuned... Pain in the butt...
To me, the Unichip is about as tunable as my Crawford Plenum....
Old May 11, 2005 | 06:02 PM
g356gear's Avatar
g356gear
Then why does APS say their tuning is MAP based to get around the MAF limitations??
Old May 12, 2005 | 05:03 AM
southern_info's Avatar
southern_info
Have anybody tried this device yet? The horsepower gains I seen on the chart is that actually at the fly or to the wheels?
