UTEC - Technical question...
While setting up my HyperTerminal on my laptop to connect to the UTEC. I only get a connection type using COM3. Now I also notice that the UTEC for the Z has a USB cable input and Rj-12 cable for serial connection but the user guide does't cover what or how they are used. My laptop is a Hp ZV6000 with all the bell and whistle except a DB9 serial port.
Would it be safe for me to assume that the USB or Rj-12 can be used in the same fashon as the DB9 to connect to the UTEC if configured to ues COM3? All port setting are currently set as per the directions in the users guide (bit per second 19200).
Help?
Help?
***Disclaimer*** I have no UTEC jet.
My understanding is that UTEC USB connection should work same as serial. Did you connect USB cable? Did “found new hardware” window pop up? Did you install USB drivers?
Port# will depend on other hardware and drivers installed on your laptop.
Help?
Help?
http://www.turboxs.com/utec350zupdate.htm
Thanks,
P.S. The RJ-12 adapter uses a RJ-12 to DB-9 harness so you will still need to use a DB-9 port on your laptop.
ILoveDrifting
Sep 7, 2015 03:15 PM
