NA UTEC tuning tips????
Old Mar 27, 2006 | 07:23 AM
350Z_LMS's Avatar
350Z_LMS
thanks anyway audible! got the message ok...I need a dyno!
Old Mar 27, 2006 | 09:56 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
it says he is in rome italy.... thats a far drive
im just a smartass. i mean no harm 350Z hehehe
Old Mar 27, 2006 | 09:58 AM
Audible Mayhem
My350z
since this is the right thread for NA tuning UTEC here is my stock timing vs my utec timing (base map for TXS +2 degrees)
here is my average....
RPM STOCK UTEC
2500 22.3 24
3000 25.2 26.3
3500 24.3 27
4000 24.1 27
4500 21 25.2
5000 22.9 21.6
5500 20.7 22.2
6000 21.9 23.5
6500 26.1 24.3
7000 26.8 24.5
on two of my runs outta 4 i had some knock at 7000 rpms, ( 01 ) not sure why it was knocking, what are you guys running the knock parameters at for a safe level thats not picking up too much..
as you can see, it is all over the place. car still runs really strong for not being tuned 13.2 @104 so i cant wait to fix this issue.... thanks to the couple of people who have answered my questions. Mike and Sharif, you both help out a tremendous amount in the 350z community....
Old Mar 27, 2006 | 01:53 PM
Audible Mayhem
My350z
update... man my timing was all over the place. been dataloggin for a while now and have a perfect 2 degree advance over the stock ecu for my NA map. car feels good. cant wait to get to the track on wed.
any of you guys tuning the utec yourself, just keep reading and asking questions. its pretty easy once you figure it all out...
Old Mar 27, 2006 | 02:56 PM
Nano's Avatar
Nano
I thought the tunerREG was not required for NA... why does everyone say it's required now?
me = EMS retard
Old Mar 27, 2006 | 03:15 PM
Audible Mayhem
My350z
its not required. its just necessary if you want to datalog your AFR along with all of your other stats so you can tune it...
Old Mar 27, 2006 | 06:05 PM
Nano's Avatar
Nano
The tunereg is necessary to tune, but not required??? What good is the utec if you can't tune?
Old Mar 27, 2006 | 06:38 PM
zzzya's Avatar
zzzya
The tuner wideband options are not needed to use the UTEC to tune the car. However, they are required if you want the UTEC to collect A/F numbers with the other data logging the UTEC can do. One can use different wideband options, mainly on a Dyno or in the car, but that data will not show up in the data logging that the UTEC will collect and display on the computer. If you are using a dyno to tune the car then the tuner options are really not needed since the dyno will coordinate rpms and A/F readings, but if you are going to tune on the road, it is strongly recommended to have one of the UTEC tuner options so that the A/F logging is coordinated with the rpms.
Old Mar 27, 2006 | 06:45 PM
ACEMAN's Avatar
ACEMAN
Master
If you follow this link it will show why you need the Tuner Reg. It adds the last column for the A/F. With out the Tuner Reg this column has no data.
http://us.st11.yimg.com/store1.yimg....1886_124893193
Later
Aceman
Old Mar 27, 2006 | 07:03 PM
Nano's Avatar
Nano
zzzzya and aceman, thanks for translating into dumbass english
it is now peeeerfectly clear
Old Mar 28, 2006 | 04:06 AM
FritzMan's Avatar
FritzMan
What RPM did you guys bump the UTEC limiter up to?
I'd like to get more RPM in Solo2 while still using the stock connecting rod bolts (deemed to be the weakest link).
I don't plan on sustain max RPM like lapping or anything, but I do expect to hit the rev limiter for a few seconds in Autocross.
I've heard recommendations from not changing it, to 7000-7200 RPM.
Old Mar 28, 2006 | 04:18 AM
Mike@Altered's Avatar
Mike@Altered
As a test I've set my rev-limiter to 7,400 for a while now, and more recently to 7,500rpm. No problems yet @ 480rwhp and the factory engine.
I have customers running up to 502rwhp with the stock rods and proper tuning. I contribute most rod failures to improperly set timing.
Hope this helps,
Old Mar 28, 2006 | 04:04 PM
Audible Mayhem
My350z
7200 hundred here, i dont think i would go any higher on my car. its nice there though, i pull the same car a whole car length in third gear when they shift with stock rev limiter
Old Mar 29, 2006 | 11:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
7300 here, but I shift no higher than 7100...
Old May 5, 2006 | 05:49 AM
zluver's Avatar
zluver
Ok guys, have some more info for you to look over. Sry its taken so long, but I have been busy with school. I am posting my dyno chart, with the A/F ratios blown up. The A/F was recorded by a tailpipe sniffer and I have stock cats, so I realize it may be off slightly. I have also made changes to the maps since this time, timing changes mostly, but I could only afford to tune for 4 runs on the dyno.
Old May 5, 2006 | 05:53 AM
zluver's Avatar
zluver
The early spike is becuase the car would knock sometimes below 3K rpms. The dyno guy even said he heard it ping once or twice and then go away. All the tuning we did on the dyno was simply fuel input changes, except for a few very minor places.
Old May 5, 2006 | 10:07 AM
  #38
OCG35Coupe's Avatar
OCG35Coupe
Originally Posted by audiblemayhem
ooppss that was supposed to be a pm WTF!!
I hate it when that happens
Old May 6, 2006 | 07:07 AM
  #39
Wholey Smokes's Avatar
Wholey Smokes
Does anyone know if one bank usually runs leaner than the other? I'm about to install my Bosch Sensor in one of my test pipes and I wanted to throw it on the side that tends to be leaner.
Old May 6, 2006 | 01:05 PM
  #40
Audible Mayhem
My350z
throw it on the driver side...
