TS ECU Reflash
Old Apr 2, 2006 | 09:29 AM
JhayRCruz's Avatar
JhayRCruz
Default TS ECU Reflash
I jus had my rpm idle bumped up to 900 recently after the install of my nismo cams. If i do a TS ECU reset, will that to put my idle back to stock??
I got DC headers, JWT pop, 5/16 spacer, Ur HFC, nismo exhaust, Ur Crank, nismo cams.
Old Apr 2, 2006 | 10:13 AM
InsaneChink's Avatar
InsaneChink
a reflash is NOT the same as doing a ECU reset
Old Apr 2, 2006 | 10:32 AM
zzzya's Avatar
zzzya
If you tell TS they will set the idle rpm at whatever you want.
Old Apr 2, 2006 | 01:20 PM
JhayRCruz's Avatar
JhayRCruz
oops..i meant TS ECU reset on their site. I want to reset the ecu and hopefully my comp can adjust to my mods better.
Old Apr 2, 2006 | 02:30 PM
Cannysage's Avatar
Cannysage
you're about due for a reflash. you may wanna dyno to see your A/F ratio. your idle may go back to normal, after couple of hundred miles of driving.
Old Apr 2, 2006 | 04:26 PM
JhayRCruz's Avatar
JhayRCruz
i dont think my idle would go back to normal cause of the cams. I had to bump it up cause it kept stalling when i reved the motor. I dont know how long itll take for my ecu to get used to my mods so thas why i want to do the TS ecu reset on their site. I want to get a utec but kinda expensive!
Old Apr 2, 2006 | 05:04 PM
zzzya's Avatar
zzzya
An ECU reset will not change anything that was actually programmed into the ECU. The reset simply eliminates the changes that the ECU has learned and takes it back to the base settings. When the dealer or whoever changed your idle rpms they actually reprogrammed the ECU.
Old Apr 2, 2006 | 11:42 PM
JhayRCruz's Avatar
JhayRCruz
thank u! Finally answered my question! Thanks a bunch! Hopefully, i feel a diff once i reset!
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
