Will I be OK without a reflash or ECU tuner???
Old Apr 26, 2006 | 06:51 AM
MustGoFastR's Avatar
MustGoFastR
Default Will I be OK without a reflash or ECU tuner???
My mods:
-Kinetix v4 plenum (considering upgrade to v+ and MREV++ lower collector)
-CNR stock size lightweight crank pulley
-JWT Popcharger
-Nismo exhaust
-IMR ground kit
Seems to be running pretty good in this configuration; I'm sure a reflash or tuner would benefit it more, but that's not the point.
I'm looking to add a set of high flow cats to the mix and wondering if I'll still be running safe without a tune???
Old Apr 26, 2006 | 09:38 AM
Dubai's Avatar
Dubai
You cant really tell if its safe or not without a dyno. go dyno your car with AFR reading and then you'll be able to know weither you're running lean or not!
Old Apr 26, 2006 | 10:54 AM
MustGoFastR
I realize engine to engine will be slightly different and I know the A/F won't be optimum. My question is whether or not I can run this combo of mods without ECU tuning and not have to worry about my engine? Surely there are others with a comparable set of mods, some that have dynoed... are your cars running ok on stock ECU?
Old Apr 26, 2006 | 11:45 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm running with my stock ECU w/o any problems (mods in sig). I am however buying a UTEC in June. I would recommend it over a flash if you plan to continue to mod. The problem with a flash is that its not a perfect adjustment to your A/F ratio.
Old Apr 26, 2006 | 07:37 PM
safil's Avatar
safil
I'm running 263whp with an injen ses catback and an Injen MR CAI. I got it dyno'd at MRC in Jersey. And it's an 05 G35 6MT coupe. Anyway, now I got the UR 3 pulley set and belts and its in the shop for a JWT clutch and flywheel combo. ANyway, gonna see if I go to MRC on sunday for another dyno. After that, depending on my gains or losses, it's time for the kinetix ssv.
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
