does VAFC2 work on our Z? or does the stock ecu change map all the time?
i want to get the VAFC2 for my car, but i saw post about our stock ecu changing the mapings and slightly adjust the a/f itself, so i want to ask if it is worth it to get it.
and does the VAFC2 fit a single din deck? coz i have after market deck, and there is a space under, i wonder if it'll fit in there.
hope you can help me out about this. thank you!
jackie
jackie
The VAFC II is for Hondas with VTEC, so no.
However the SAFC II will work with the 350Z. I have had one on mine for a long time now and it works just fine. There are definitely better ways to tune the Z as the SAFC II only does A/F, but it will definitely work.
As far as working in a single din, I don't think it will. I have mine mounted on the dask just above and to the right of the instument cluster where it is easily in view while driving.
It has a digital tach and knock sensor readings built in, so I felt it was something good to have in view.
