Maf and Utec...
Old Jun 26, 2006 | 10:42 PM
cox's Avatar
cox
Question Maf and Utec...
Anyone have problems with Maf after Utec installing?
My Z for two times in two weeks wont start.... the Maf voltage is at 5,5 and the car is turned off.....
Please help me....
Thanks
Cosimo
Old Jun 27, 2006 | 08:06 AM
cox's Avatar
cox
Old Jun 28, 2006 | 03:51 AM
350Z_LMS's Avatar
350Z_LMS
a quanto pare non ti si caga nessuno
Old Jun 28, 2006 | 04:04 AM
cox's Avatar
cox
hai ragione
Old Jun 28, 2006 | 04:22 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
pasta !!
Old Jun 28, 2006 | 04:49 AM
cox's Avatar
cox
Nobody helps me...
Old Jun 28, 2006 | 07:08 AM
Kiamo's Avatar
Kiamo
Is the UTEC grounded as mentioned here: https://my350z.com/forum/showpost.ph...2&postcount=47 (pic of where: https://my350z.com/forum/showpost.ph...9&postcount=80 )
Does the car operate fine with the UTEC out?
Are both the switches on the TurboXS logo side of the unit in the proper direction (towards the large harness connector)?
Does the check engine light come on? Do you have an aftermarket intake?
Old Jun 28, 2006 | 07:54 AM
350Z_LMS's Avatar
350Z_LMS
I'll do the "talking" for him:
1. yes, UTEC is grounded as suggested;
2. yes, the car runs just fine without the UTEC;
3. don't know, will ask;
4. CEL come on with P0103 error code;
5. Crawford plenum
Old Jun 28, 2006 | 08:01 AM
cox's Avatar
cox
5. Crawford plenum
Thanks Marco
Old Jun 28, 2006 | 08:09 AM
BlackTuner's Avatar
BlackTuner
Do the following things:
1) Make sure the UTEC Switches are in the Proper position. With the UTEC in the upright position both toggle switches should be down or away from the TurboXS Logo.
2) Check the Plug and Play Connectors. It is very easy to have the rubber gromet bind and cause an improper connection.
3) If all of these items are ok. Try to run the UTEC in stock mode. If the vehicle does not run properly, return the UTEC to your dealer.
This also assumes you have grounded your UTEC properly.
Thanks,
Jermaine~
Old Jun 28, 2006 | 08:19 AM
350Z_LMS's Avatar
350Z_LMS
Will check toggle switches. UTEC has been properly grounded as per your indication. bear in mind that the car wouldn't start with the UTEC on, even though it had been running for over a week. so I had to disconnect it in order to start the car. I think *** is really disappointed...
Old Jun 28, 2006 | 08:20 AM
350Z_LMS's Avatar
350Z_LMS
oops his mechanic disconnected the UTEC, not me!
Old Jun 28, 2006 | 08:22 AM
cox's Avatar
cox
You are correct Marco....
I'm very very disappointed....
Old Jun 29, 2006 | 12:56 PM
cox's Avatar
cox
I've made everything Jermaine said... but my Z doesnt work....
Without the Utec the car runs fine....
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
