H E L P ! My ECU is fried!!!
Old Jul 28, 2006 | 11:26 AM
Sportec's Avatar
Sportec
Originally Posted by bhk1004
i doubt there is any way that any of your mods caused this damage.
+1
what can I do now?
Anyone with any expirience on Motec M600???
Old Jul 28, 2006 | 11:27 AM
002-M-P's Avatar
002-M-P
Originally Posted by Sportec
Thats no problem for me. I have an MCC smart. I does the job. the problem is that the main dealer is not recognizing the warranty because i have a new catback exhaust with racing cats and a grounding kit. They say that the car has mods and thw warranty is void!!!
take the mods off and then bring it in.
Old Jul 28, 2006 | 11:30 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Don't forget to wear sunglasses and a fake moustache!
Old Jul 28, 2006 | 11:33 AM
Sportec's Avatar
Sportec
Originally Posted by gsazabi
I've seen HKS F-Con, which is full standalone, on a G35 today.
I'm assuming you can get one for Z also. Only drawback is that it's expensive...
Its not the only drawback... It also needs an HKS dealer to program it. the closest one is 350miles away....
The only 2 I found are the HKS F-CON vPRO and the Motec M600. Both need to replace the engine wiring which is a pain in the a$$!!!
Anyone with expirience on HKS or Motec???
Old Jul 28, 2006 | 11:35 AM
Sportec's Avatar
Sportec
Cool
like this?
Old Jul 28, 2006 | 03:55 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there is also a Magnetti Marelli setup via Injected Performance (good guys). It goes for around $5k - which I am sure is a ton more than a stock ecu costs.
Old Jul 28, 2006 | 07:27 PM
bofa's Avatar
bofa
He's not in the US.. may not be as easy to fight this...
Old Jul 29, 2006 | 05:42 AM
mistaboosta's Avatar
mistaboosta
www.nizpro.com.au
These guys are selling plug'n'play MOTEC ecu for 350Z.
Let me know if you need tuning support.
Old Jul 29, 2006 | 11:39 PM
Sportec's Avatar
Sportec
Originally Posted by mistaboosta
www.nizpro.com.au
Thanks.
I just send them an e-mail and waiting for their answer. Didn't find anything on their site though.
Old Jul 30, 2006 | 11:23 PM
Sportec's Avatar
Sportec
www.nizpro.com.au
This PnP Motec requires the stock ECU as well...
Old Jul 31, 2006 | 01:06 AM
Z350Lover's Avatar
Z350Lover
I am using motec M600 from Nizpro...
You can have it works as standalone or works with the stock ecu...
Motec basically takes over the entire engine management side... the way mine got wired is to have the stock DBW still working with the motec because it is very tricky to tune the motec dbw pefectly without jerking..
cheers,
richie
Old Jul 31, 2006 | 03:10 AM
Sportec's Avatar
Sportec
cheers,
richie
The thing is that my ecu works fine exept from the 4th cylinder's coil command. If the motec goes parallel will it work? Does this configuration cuts of any communication of the stock ecu with the engine?
Old Jul 31, 2006 | 05:49 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
That is total BS! You need to fight that
Old Jul 31, 2006 | 07:22 AM
S12 driver's Avatar
S12 driver
Can't you still use the broken stock ECU with UTEC or any other paralelle engine controller tho? Cuz UTEC has it's own injector and ignition driver, so it should be fine even if your ECU's ignition is broken. The stock ECU is just there to take care of the A/C and lights and satnav.
Old Jul 31, 2006 | 09:12 AM
gringott's Avatar
gringott
Correct me if I am wrong, but at idle doesn't the stock ECU control injection - ignition when using the UTEC? Perhaps one of the UTEC experts can help this man with his problem.
Old Jul 31, 2006 | 10:37 AM
Sportec's Avatar
Sportec
Yes Plz!!!! Any experts on UTEC? Does anyone have close pictures of the utec plug that connects with the stock ECU???
Old Jul 31, 2006 | 11:31 AM
mistaboosta
You mustn't use neither UTEC nor MOTEC with your current ECU if it isn't controlling Cyl 4. Both systems leave the idle to stock ECU. UTEC takes control of the Fueling and Ignition after some variables are in line (like boost level, rpm, TPS) and MOTEC takes control when the car isn't @ idle anymore. So your car won't be fueling Cyl 4 @ idle. You need a complete standalone for your car.
Old Aug 6, 2006 | 08:46 AM
  #38
Sportec's Avatar
Sportec
I am going to fight this. I will ask the nissan dealer (!!!when the service guys return from vacation!!!) to replace the ECU for free.
Old Aug 12, 2006 | 05:18 AM
  #39
skyydiver's Avatar
skyydiver
Technosquare can do ECU duplications. I don't know if this will help or not:
http://www.technosquareinc.com/350z.htm#ecudup
I know you are out of the USA so see this link as well:
http://www.technosquareinc.com/foreigninfo.htm
Best of Luck To Ya!
-J
Old Aug 12, 2006 | 09:11 PM
  #40
QuadCam's Avatar
QuadCam
what about the F.A.S.T. standalone. I see that in alot of single second 1/4 mile cars.
