UTEC Map help
Old Aug 20, 2006 | 12:43 PM
techcontrol's Avatar
techcontrol
Default UTEC Map help
I'm trying to build a 93 Oct, N/A map extrapulated from the following data. I could really use some help here. I've included an edited CIPHER log, if anyone would care to view it and give advice I'd really appreciate it.
If it makes any difference, I currently have the following mods. Strup headers, UR HFCs, NISMO cat-back, Injen CAI. Our average daily temp is 100 for now.
Thanks again,
Rick
File Type: txt
Old Aug 20, 2006 | 03:05 PM
Kenk2's Avatar
Kenk2
Professional
I am not familiar with this type of log but I can try my best.. Show me what columns are most important and I will try to gather some info..
Old Aug 20, 2006 | 03:26 PM
techcontrol
I appreciate the help, the log is not formatted correctly. Don' t pay attention to the placement of the column titles they're way off. Look at the data and count, columns 4,5,7,8. 4 & 5 are wideband voltage. Which I can't correct to ratio because I can't find the formula. Column 7 is RPM, and 8 is timing BTDC.
Perhaps I should get the tuner just for this reason.
Old Aug 20, 2006 | 03:30 PM
Kenk2's Avatar
Kenk2
Professional
I would! But in the meantime I will see what I can do..
Old Aug 20, 2006 | 03:35 PM
techcontrol
I just might get the tuner. I thought since I have an 05' which already has widebands that the UTEC would log this data without a tuner. The only thing i get A/F ratio wise from the UTEC is "RICH". Like that helps..
Old Aug 20, 2006 | 04:07 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yeah man, the wideband voltage is hard to follow. i would get a tuner wideband so it will all datalog it on one screen with no problems. then i can help you tuning your own car if you need help. ask kenk2 if i know what i am talking about!! hehe
Old Aug 20, 2006 | 04:13 PM
techcontrol
I followed the thread between you two. I even tried the map you posted. Sadly, the RPM climbed much slower and then fell on it's face at 6,000. Are you guys installing the 02 bung at the "Y"? I seen some people do this but questioned the accuracy because it's so far downstream. I guess it's time to add more weight to the Z.
Old Aug 20, 2006 | 04:41 PM
Audible Mayhem
My350z
dont add any more weight!!! hehe
no , i put the bungs at the top of the test pipes on the driver side. both sides read almost the same, but reported that driver side runs a little leaner..
my map runs pretty rich in everyones cars, im sure its cause i ported out my lower runner and some other top secret things so i had more air going in...
Old Aug 20, 2006 | 04:53 PM
techcontrol
As for your map, I figured it was something like that. I suspect that once I put the R-tune cams (sitting in the garage) in, your map would better suit my needs. As for the weight, I can't breakout out the saw . This is still my DD. Since I have your mad genuis minds' attention, do you know the formula for converting the 02 voltage to A/F ratio? I've must have read through 45 google searches and came up with nothing useful.
Old Aug 21, 2006 | 02:54 PM
techcontrol
Just so everyone knows, Cipher will compute AFR via WB 1 & 2. You have to select it under options and answer a few questions, like WB part numbers (already in there) and ECU part number, which comes up when you connect to vehicle anyway.
I got a friendly reminder from UpRev this morning about that option. Sorry I confused anyone with all my nonsense.
Ken...A BIG thanks you for all your help!
Rick
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
