Vortech SS Box
Old Sep 21, 2006 | 09:44 AM
booger's Avatar
booger
Yes ...you can tune fuel and retard timing with the SS box
Old Sep 21, 2006 | 04:10 PM
jibolean's Avatar
jibolean
Well, it turns out it was the serial cable. I've connected and logged some runs. Boost is working fine. It was surprising about where the Vortech is making boost. It doesn't hit full boost until well into 6000's. I've purchased the Innovate products to log AFR and other info, hoping to install soon. Then going to tune the SS box as need.
Old Sep 21, 2006 | 04:17 PM
jibolean's Avatar
jibolean
As far as the AFR goes, should I be tuning for that 11-12 AFR through out the entire rpm band at WOT? Or should I be tuning for 11-12 at any point during open loop mode? Any tuners out there that can advise?
Old Sep 22, 2006 | 03:15 PM
RA11325's Avatar
RA11325
Originally Posted by THE TECH
Running lean up top is a common issue with an untuned SS box. I'd just take your car to the dyno.
Mine runs 9.5 A/F all the way up.
Old Sep 22, 2006 | 06:20 PM
skyydiver's Avatar
skyydiver
Is this common with the Vortech kits that they only reach full boost at or around 6000rpms?
Old Sep 22, 2006 | 07:35 PM
booger's Avatar
booger
With the Vortech SC you will not see full boost till redline . The more rpms , the faster the blower spins
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
