UTEC Map Sensory reading +.4 lbs of boost at idle?
Old Sep 21, 2006 | 10:22 PM
veilside350zTT's Avatar
veilside350zTT
Default UTEC Map Sensory reading +.4 lbs of boost at idle?
Ok guys here is what is going on. Just got my car up and running.. fully built long block (builtZmotors).. Tonight me and a buddy were messin with my utec and we are encountering this problem...
Map sensor is reading a +.4 even at idle causing my load site to be at 10% when it should be at 0% during idle.. this of course is causing me to run EXTREMELY Rich.
Any ideas on why im reading a +.4 when my Boost gauge display a -.4 ??
thanks,
Arash
Old Sep 22, 2006 | 11:30 AM
BlackTuner's Avatar
BlackTuner
thanks,
Arash
Post your calibration car numbers please?
Thanks,
Jermaine@turboxs.com
Old Sep 22, 2006 | 08:24 PM
BrokeZ's Avatar
BrokeZ
his gradient is 121
intercept 180
also, i have found that his map reading barely fluctuates, even while driving.
On my car at idle, mhy map reads around -15 absolute.
Old Sep 22, 2006 | 08:49 PM
QuadCam's Avatar
QuadCam
if I remeber correctly, my UTEC had stock values or 112/169
do you have the calibration card numbers? post them, and I report back the gradient and intercept. I have an Excel file from TXS.
I need the:
Cal 1 Input
Cal 1 Output
Cal 2 input
Cal 2 Output
(all in psi)
These are the 4 number on the top part of the calibration card.
Old Sep 23, 2006 | 08:49 AM
BrokeZ's Avatar
BrokeZ
hey quad, can you convert mine..i just want to make sure its correct.
CAL 1 IN: 1180 CAL 1 OUT: 7.35
CAL 2 IN: 1717 CAL 2 OUT: 20.57
Old Sep 23, 2006 | 02:43 PM
QuadCam's Avatar
QuadCam
your numbers give this:
GRADIENT: 120
INTERCEPT: 180
Old Sep 23, 2006 | 02:45 PM
QuadCam's Avatar
QuadCam
Here's the file:
File Type: zip
Old Sep 24, 2006 | 02:53 AM
BrokeZ's Avatar
BrokeZ
Cool, thanks a bunch quad. Once we find veilside's map sensor card, we should have no problem inputing the right #'s....
Old Sep 24, 2006 | 05:15 PM
QuadCam's Avatar
QuadCam
glad I could help.
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
