UTEC wideband compatibility
Old Oct 6, 2006 | 05:05 PM
rcdash's Avatar
rcdash
Default UTEC MAP sensor compatibility
Guys,
I have read posts that the TurboXS MAP sensor is required for the UTEC to run in speed density mode (which I don't need right away till I go FI).
Do I have to get a turboXS MAP sensor or will the Zeitronix MAP sensor output work just as well. Anyone have this combo? I'd just as soon get a LCD display w/ boost gauge + WB O2 for the price of the Tuner reg, which has only the WB02.
Old Oct 6, 2006 | 08:16 PM
rcdash's Avatar
rcdash
I found a post about calibrating the MAP input, so I figure any 0-5V map sensor (like the wideband analog output on the Zeitronix) should work fine.
Would appreciate anyone confirming if they have used a non-turboxs MAP sensor successfully with the UTEC.
Old Oct 7, 2006 | 05:36 AM
SmokyTyrz's Avatar
SmokyTyrz
Do you mean the O2 sensor? If so, the one that comes with the Tuner is a Bosch (or VW, if you choose).
The proprietary piece is the cable between the WB O2 harness and the Tuner.
Old Oct 7, 2006 | 07:20 AM
rcdash's Avatar
rcdash
Sorry, I meant MAP sensor (I edited the posts above). As far as I know, there is no WB02 input on the UTEC (only the tuner/pro).
If the UTEC has a MAP sensor input, then how does one get a boost gauge (or a device such as the zeitronix) to read the input also? Just split it off into two leads?
My planned config is:
WBO2 >>> Zeitronix >>> serial cable to carPC with input read by mps_utecLogger software
MAP input >>> Zeitronix & UTEC (somehow???)
UTEC >>> USB cable to carPC with input read by mps_utecLogger software
2ndchanceZ
Oct 26, 2015 08:03 PM
SharX59
Sep 27, 2015 09:23 AM
